Did my first TBI Mod
Old Feb 2, 2008 | 01:16 PM
Mike305RS's Avatar
Slapped on an open element air cleaner this morning. Sounds nice, and the butt dyno feels good too.
Now I just gotta clean that engine bay up!
Old Feb 2, 2008 | 01:44 PM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
Re: Did my first TBI Mod
some crome never did anyone wrong.. Now ya need some simple green and a tooth brush.. Dont forget to polish the evap for the a/c
Old Feb 2, 2008 | 02:45 PM
deadtrend1's Avatar
Why bother polishing it if he has the A/C delete already. Just get rid of it along with the lines.
Good Job, clean up the bay a little bit and it will look pretty decent.
Old Feb 2, 2008 | 03:00 PM
Mike305RS's Avatar
Yeah I wanna lose the rest of the AC stuff, and my smog pump. I'll probably just do it when I put headers on. Speaking of which looks like it's going to be a PITA to get the stock ones off with all that AIR and smog crap on them.
Old Feb 2, 2008 | 03:32 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
once you pull the A/C stuff out it's not THAT bad.
Old Feb 2, 2008 | 04:09 PM
badazta87's Avatar
Car: 87 GTA
Axle/Gears: 3.70:1
good lookin out I didnt even notice.
Old Feb 2, 2008 | 04:25 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
is that a drop base air cleaner though? yes better than the stock by a long shot but the Mr. gasket "small" drop base air cleaner without the gold spacer felps the most IMO. But a great start!
Old Feb 2, 2008 | 06:18 PM
Mike305RS's Avatar
yeah it's a drop base. I really wanted to use a 3" filter and i thought I might clear it without using the spacer but it's just a hair too short. I may have a machine shop make me a 1/4 inch aluminum ring or something. I'm probably going to carb the motor anyway though so I may just stick with this for now. I need headers and exhaust bad before anything else. Then gears and posi.
Old Feb 2, 2008 | 07:23 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
youshould be hitting the coil, unbolt it and put the round hole at the back bolt of the throttle bracket and bolt it there so it open air hangs, it'll also keep the coil cooler, just did it on my new camaro, I'll post pics
Old Feb 2, 2008 | 08:10 PM
Mike305RS's Avatar
I bent the metal back that the coil is on so there is like an inch of space.
Old Feb 2, 2008 | 08:20 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You can should have just gotten a flat base, then you wouldn't have to worry about the coil, but more importantly, that restrictive gold ring on top of the TB!!! Oh well, just wanted to point that out for future readers of this thread.
Old Feb 2, 2008 | 09:31 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Doesent using a flat base require clearencing for the throttle linkage?
Also, the parts stors dont generally carry flat base around here.
Old Feb 2, 2008 | 10:23 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i have a falt base, with all the ultimate TBI mods, no linkage issue
i have a flat bottom edelbrock elite
Mike305RS's Avatar
There was a spectre 2" air cleaner at autozone but it was only 10" wide too, but it was flat. I actually got that one first, and it was too small, I had to use the base for that one too to clear the linkage as stated above.
What size cleaner do you have on it?
Old Feb 2, 2008 | 10:32 PM
krisb410's Avatar
No, it does effect the throttle linkage in any way. I never even heard that.
Well, why settle for what they have on the shelf. For the most part, they will order whatever you want if you ask them.
Old Feb 2, 2008 | 11:25 PM
89RS_82Z's Avatar
10" round 3 3/4" tall
Old Feb 2, 2008 | 11:38 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
When i did my motor swap the 350 TBI i used never had smog on it and i deleted the AC while putting it in cause it didn't work anyways. Good luck with the 305 its a good motor.
Old Feb 2, 2008 | 11:55 PM
Engine: LO3
Well whenever I get one, I want the cheapest flat base I can find I guess. I will rattle can it flat black to get rid of the chrome look.
Old Feb 3, 2008 | 12:33 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
thats exatly waht i did to my 305
slap on a chome aircleaner. i had no idea if it will fit or not. cost me $20 at the local store. and it fits good to i was suprized and im happy i also got rid of all the smog stuff and what not. and got rid of the windshield washer fluid stuff. cleaned it out abit more.
and i quickly sprayed on some engine cleaner. that helped abit as well. and did alittle bit of polish work on any open metal. about an hour or so of work and it really cleaned it up good
ill take a snap shot of it. i think i have an after and before photo.
Old Feb 3, 2008 | 08:32 PM
Engine: LO3
Well I dont see the point of removing all the smog stuff, because it will only be nice untill the emissions guy fails me, and DMV pulls the reg.
And the washer fluid is a nesessity to me. Use it daily.
Old Feb 3, 2008 | 10:15 PM
krisb410's Avatar
I put in a 4th gen washer tank. Just had to extend the hose and wires. Real easy mod.
I plan on useing a 4th gen coolant overflow as well, just haven't gotten around to it yet.
BLK87Z
Sep 18, 2015 11:29 PM
89bird2.8
Sep 18, 2015 07:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
