Crossfire needs to go?
Old Mar 10, 2008 | 05:25 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Hey guys, iv been here a few times about my crossfire injection problems.. As some of you might know it likes to stall after its ben doing alot of stop and go traffic. Well i wnt to change the thermostat and there was a lack of one in the first place.. so i put one in and it seemd to fix my problems.. for about 3 days. then boom back to its usual "stall and not start back up self". It really gets annoying.. i guess my next step is to put a CTS in it? and if that doesnt work i have no idea what to do other than going carburated.
Old Mar 10, 2008 | 06:30 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Crossfire needs to go?
Check your fuel pressure. Fuel starvation can be attributed to a tired FP - take a look at fuel spray from injector during no start cranking.
//RF
Old Mar 10, 2008 | 06:40 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
If anything its flooding.. when i go to start it back up i have to hold it to the floor to get it going again.. then i have to sit there keeping the rpms up untill it starts running right again.. wich can take from 2-5 mins. then it will run fine for a little tiny bit.(few mins) and do it all over again.
Old Mar 10, 2008 | 07:04 PM
RFmaster's Avatar
Car: 75 Beast
You can check CTS very easy - disconnect harness connector and at room temperature (22C) CTS sensor should read (measured with DVM) about 2700 Ohms. If it reads very high resistance (with warm engine), more than 2700 Ohms - replace it.
//RF
Old Mar 10, 2008 | 07:33 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
pull that "cease" fire injection set up and make it a garage wall ornament.
Old Mar 10, 2008 | 08:57 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
First question - you have crossfire on an '87 350?? Second question - have you posted your questions on the crossfire forum? The forum is full of highly experienced guys that can really help and aren't ignorant tards that use really cute names for injection systems just because they don't know how to follow a schematic and use common logic to tune electronic fuel injection. The link is http://www.crossfire.homeip.net/cftest/startdefault.asp Give it a shot before you do anything rash.
Old Mar 11, 2008 | 09:09 PM
Common logic my a$$, unless you want to keep the crossfire setup for nostalgia in terms of just keeping the car stock and period correct, well then go for it. If you're out for any kind of performance with it, forget it....but who knows, n1ffer might just have a 450hp crossfire injected small block
Old Mar 12, 2008 | 12:07 AM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Hehe, right now im just looking to keep it on the road untill i get the money for my Carb setup:P
aye and its pre 87 350 im pretty sure.. the car is an 1983 camaro z28 CFI..
Old Mar 18, 2008 | 01:36 PM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
Are your injectors spraying correctly?
Check your throttle position sensor using a digital voltmeter. It should be at .525 +/-.025 volts.
Are you getting a check engine light?
How about the idle air controllers? Are they in good shape and screwed in tight?
That's about all I can think of at the moment. Ask as the crossfire forum like the other guy said. Those guys actually know what they're talking about and they're happy to help. Just don't mention a carb around there, hehe.
Whenever you're ready to get rid of that "useless" CFI setup, send me a PM Micro
Oh and if that's the original engine in the car, it isn't a 350.
Old Mar 18, 2008 | 06:40 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Heh, yeah its not the original motor just the intake setup is original, and iv fixed the stalling.. so far.. by replacing the connector for the collant temp sensor... the wires were bare were they went into the connector, i just didnt notice because of all gunk around them lol.
NZKnight
Oct 15, 2015 02:47 PM
Tweeks25
Sep 17, 2015 08:04 AM
edoff13
Sep 11, 2015 03:55 AM
3rdgenparts
Aug 6, 2015 09:03 AM
