won't run w/ est unhooked
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i'am trying to base time this car right. but it won't run with est wire unhooked.any ideas ?
Car: check
Engine: check
Transmission: check
Re: won't run w/ est unhooked
Not unusual. Opening the BYPASS connector pulls 15 to 20 degrees of advance.
Get the engine up to temperature first, then shut off the engine and open the connector. Start it up and it should now idle. If it has trouble give it a little throttle to keep it going. Once the IAC opens enough it should stay running.
RBob.
RBob.
dhonda200
Aug 11, 2015 11:50 PM
