need some advise on putting a 72 355 motor in my 89 camaro TBI question
Old Apr 20, 2008 | 11:21 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
im trying for the life of me to figure out how i would go about doing this. the 355 has old heads but the motor has been gone through and id rather not change the heads so the factory tbi intake works cause they have the different bolt angle in the middle bolts.so i was thinking about getting a egr edelbrock manifold and a plate adapter from a 454 tbi so i can bolt it to the intake. is there an easier way to do this? also the heads are stock but i have a .488 lift comp cam and its bored .30 over. will i have an issue with the fuel pump or a stock 350 tbi unit? just getting some answers to some of the questions ive come up with. thanks
Old Apr 24, 2008 | 12:06 AM
GMZombie's Avatar
Re: need some advise on putting a 72 355 motor in my 89 camaro TBI question
no answers on this?
Old Apr 24, 2008 | 12:58 AM
squeeezer's Avatar
Car: 5 cars
holley projection manifold
drill the center 4 bolts at yor head angle use washers and a little rtv
Old Apr 26, 2008 | 10:16 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
I would also like to add to that: I have found that if you purchase some 3/4" solid tube stock you can "slice" the angle into the bar stock then drill a hole in the center. When your done you will end up with a washer that is thicker on one side than the other. In my opinion it distributes the pressure more evenly.
You will also want to modify your dipstick. I took my stock dipstick and trimmed the portion of the tube where the stick slides in until it read "full" on the stick. If you use your factory dipstick on the old motor it wont read correctly unless you do this.
You will aslo have to block off plate your mechanical fuel pump on the early block.
If your using roller rockers and tall valve covers, be aware that you will not be able to remove the valve cover easily if your using AC. The manifold on the back of the ac unit projects too far to allow you to remove it easily. Recharge your AC AFTER your valve adjustments are done.
Be sure you use the water pump from the late model block...not the early block.
If your using a gear drive, disable any knock retard in your chip. The ecm hears the whine as a knock.
You will also have to switch out your flywheel.
Other than that it's pretty simple. Other than the intake trick, everything bolts up just like it was on the original motor.
Hope this helps, Brandon
I further read your post...You will also need to farmilurize yourself with tuning. Your are changing the airflow considerably and will need tuning...especially at idle.
Last edited by Brandon2350; Apr 26, 2008 at 10:21 PM. Reason: Automerged Doublepost
Old Apr 30, 2008 | 09:17 PM
Your fuel delivery system is also adequate...with the exception that your stock injectors may not be large enough without actually knowing what your running.
If money is an issue, Tune it with the tbi you already have then when you get everything running pretty decent swap in a 2" tbi to allow it to breathe. Getting enough air is a concern with your combo but it will run decent using what you have.
Old May 4, 2008 | 12:19 PM
GMZombie's Avatar
Since i have to get an intake that has an egr valve on it cause id rather not use a stock intake i was thinking about this
SB-Chevy Intake Manifold
Idle-6000 RPM
High rise/dual plane
Height: 3.68" front/5.02" rear
Port size: 1.9" tall/1.16" wide
Square flange carb mounting
EGR provision 510-300-48 found this on ebay
and to get the throttle body on that i found this
THIS WILL BOLT TO ANY QJET OR INTAKE THAT HAS A SPREADBORE BOLT PATTERN WHICH IS 4 & 1/4" TO 5 & 1/2" CENTER OF BOLT HOLES. THROTTLE BORE HOLES ARE 2". YOU CAN PUT THIS ON A SPREADBORE INTAKE, THIS WAY YOU DON'T HAVE TO BUY GASKETS & A T.B. INTAKE. YOU CAN RUN A 4.3 350 OR 454 T.B. ON THIS ADAPTER. GM P/N 10085769. IT IS 1 & 3/4" TALL, USED & ALUMINUM. THIS ALSO HELPS GET THE GAS UP OFF THE INTAKE TO COOL IT OFF FOR BETTER PERFORMANCE
do you guys think this will work or am i in the wrong boat?
Attached Thumbnails need some advise on putting a 72 355 motor in my 89 camaro TBI question-7f2f_1.jpg   need some advise on putting a 72 355 motor in my 89 camaro TBI question-4237_1.jpg
Old May 4, 2008 | 08:08 PM
Nope...Your on the right track, but hood clearance might be a problem though. To give you an idea...I have an Edelbrock Performer intake. I purchased a 2" TBI unit from a 454 then I used the exact same adaptor in your pic to bolt it up to the intake. Then I took my stock air lid and placed it on top of the tbi. The complete unit ( bottom of manifold to top of air cleaner lid measured 13" +) This is considerably taller than the factory combo. I'm bolting this unit up in a 93 pickup and it looks like it will just clear by about 1/2".
It will work but I'm thinking clearance might be a problem in a car application unless you find a lower profile air cleaner assembly.
Anyone else have suggestions?
Old May 4, 2008 | 10:44 PM
GMZombie's Avatar
i dont have a stock hood i have the ram air version 2 hood so clearence shouldnt be a problem
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
InfinityShade
Aug 22, 2015 08:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Amillionoh7
Aug 7, 2015 01:24 PM
