Still throwing 33 at idle in gear.
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Hey guys. Here's the situation. Built 355 (made 500hp using 850 dp) / Stock TBI / 4l60 e / 16168625 ecm.
EGR disabled thru the chip, countless hours of balancing iac / tps to get a stable idle and about 300 burns to date.
My problem is in-gear stalling. It's still a little rich at idle. I drive it anyways and tinker with the fuel and spak tables little by little when I have the time. I havent been too concerned because I have a modded 2" tbi and intake that I'm trying to find the time to bolt on.
It will idle all day long in park or neutral but after I put it into gear it will die after about 15-20 seconds. (code 33 high map). It starts right back up and runs great again. As long as you are moving faster than about 3 mph it wont do it. Any less than that, than you have to put it into neutral so it wont throw 33 and die.
It has a very stable idle at 1000 rpm (stable for what it is) It's not an issue that putting it into gear is lugging down the rpm. This was a very difficult motor to tune. It idles at about 60 - 65 map.
So if you want to use my truck...put it in neutral when you come to a stop light. other than that it has no other quirks! Any suggestions on tuning this anoying gremlin out....I'm going to wear out my shifter linkage if I keep driving it this way! LOL
Thank You, Brandon
Thank You, Brandon
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Still throwing 33 at idle in gear.
Thank You, Brandon
Thank You, Brandon
;-Error 33: MAP sensor hi
L4E56 FCB 10 ;4% TPS, upper threshold to set error
L4E57 FCB 156 ;68 kPa, lower baro limit, MAP diags.
L4E58 FCB 50 ;5 secs, time threshold to set error
L4E59 FCB 0 ;0 RPM, scaled RPM threshold to set error
Thanks Fast!
Thats exactly what I needed! I'll try it later this week and post my results.
Brandon
Brandon
