Open Element Air Cleaner is Worth It!
Old May 29, 2008 | 09:25 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
Just bought one at Schucks and I'll say it is Awesome! It defiantly has better throttle response and actually sounds way better than stock at WOT or close too it.i would say that this is one of the best things i have ever spent $20 and is very easy to install just make sure your coil doesn't touch. just had to do a few mods since the cleaner i got wasn't a flat one it was a drop.just thought i would post this for anyone wondering about switching to the open element it IS worth it!
Old May 29, 2008 | 09:35 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: Open Element Air Cleaner is Worth It!
Yay!
The next low cost thing you should do is get a Wonder Bar.
After that, start saving for a full 3 inch exhaust with headers.
Don't forget the utimate TBI mods!
Old May 30, 2008 | 12:58 AM
Jix01's Avatar
Engine: 305 5.0 TBI
is a wonder bar the bar that hooks up on top of both of your shocks and gos across the engine? is that just for style or does it help the shocks or something? just wondering
Old May 30, 2008 | 01:30 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
the wonder bar mounts underneith your sway bar, bracing the steering box area. well worth 60$. get one.
Old May 30, 2008 | 02:21 AM
Jix01's Avatar
Engine: 305 5.0 TBI
right on thanks i will invest into that lol
Old May 31, 2008 | 09:27 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
the only problem with the open element is that once the engine warms up, you are sucking in very hot air. the flow is remarkably better, but the hot air is not. just a thought. can't beat it for $20 though.
as posted above, definately get the wonderbar! it is worth it. certain older irocs had them from the factory as well. it keeps the frame horns from being pushed apart when turning the wide-a$$ tires.
after that you'll want...
a COMPLETE exaust (headers back) tbi mods as someone else posted
gears and a limited slip
find an aluminum drive shaft out of an LS1-powered fbody (fits as is)
sfc's (sub-frame connectors)
the list goes on and on and on...
Old Jun 1, 2008 | 07:19 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
I got my car with the open element.
I removed the spacer, did the tbi mods, moved the coil onto the firewall, shorty headers, true dual sidepipes, FULL ignition (with 7AL-2 box)
and mild tranny and suspesion upgrades. I never expected to have as much power as I got out of it, but then again it is a roller 350
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
