open element or Ram air? TBI
Old May 31, 2008 | 09:09 AM
tonkpils1769's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
hey guys i got a 305 with TBI i have a open element on the TBI now but i was wondering if i put togather my own custom Ram Air Intake for it which would preform better? which would give a better HP rating? would like to know before i run out and buy what i need.
Old May 31, 2008 | 08:50 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
Re: open element or Ram air? TBI
https://www.thirdgen.org/forums/tbi/...tml?highlight=
this is what i did on my old 92 rs. found a tbi cadillac intake piece to go directly over the tbi. after that find a tpi engine or 2.8/3.1 car in a salvage yard and get the intake piping and the bracket it attaches to in the bumper. therers some baffles that you can cut out too. get 2 k&n drop in filters and you're set. this is just one of many options, but i found this rather cost-effective since i already had the stuff from parting out my old z.
as for what performs better? i never got any dyno results; however, the open element has good flow, but it is sucking in hot air from under the hood.
don't forget to read the stickies, especially the free tbi mods. welcome to the forum
damn i really miss my 3rd gen.
Old Jun 1, 2008 | 07:35 AM
Car: 90 Camaro RS
Engine: 305 TBI
Thanks alot i already read the stickies i just wanted a personal opinion on it from others.. i did know the open element sucks in hot air from the engine under the hood so i figured a custom ram air would be alot better for preformance sence it would be getting freash cool air.
Old Jun 2, 2008 | 04:30 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Definally DIY, there is nothing extraordinary for these cars on the market.
https://www.thirdgen.org/forums/tbi/...ir-intake.html
Old Jun 2, 2008 | 08:21 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
I recently installed a open air element to see how it performed. As for power increase, I could feel nothing. Sound was good, like a 4 bbl. Nice and throaty. Water temp went up a few degrees, due to the hot air being sucked in. Gas mileage dropped, I guess due to the hotter air charge. Final result... I took it off. I didn't like how close it sat to the coil, and the drop in mileage, and rise in temp, was not worth it to me. I've been working on a set of scoops for the hood, and when they're finished, I they they'll show a bigger increase in power, and a much cooler charge. I recommend the ram air.
Old Jun 3, 2008 | 02:22 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have a 92 with a L03 and T5 but I have long tube headers and a full 3.5 catback with flomaster muffler and I noticed a difference when I went to open air. Before the change it was hard to burn out or break the rear loose with a clutch kick but after it would do it without trying. The great thing is I didn't loose any mpg and im on a 187k original engine and its still running strong.
Old Jun 3, 2008 | 03:45 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
I'm in the middle of a Ram air setup. Took L69 air cleaner, cut the bottom off and riveted on the Mr. gasket non-drop base. Then filled the gaps with a gasket sealer.
just need the hoses and scoops.
It's kinda a long process... also had to get some hoses with 90* ends for the heater hoses. Than more for moving the air divertor.
I felt a difference even without the hoses connected
Brinkkl2000
Aug 4, 2018 08:29 AM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
bryan623
Aug 10, 2015 11:33 AM
