305 tbi injectors
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: 305 tbi injectors
You can stick them in there but the car will run like poo. The computer won't know what's going on.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
IDK if the trucks are different, but my buddie put them in his 305 TBI truck (95??) with the dual stud cleaner, and it gave him additional power.
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
It shouldnt run any different because it will still be pushing fuel through at the normal rate shouldnt it? only if you wanted to run fuel at the pace of a 350 would you than require a tune.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
They have different flow rates, check this page for info:
http://diy-efi.org/gmecm/component_i...injectors.html
Im still new injectors and tuning them, but would a tune be necissary if you bolted on 350 injectors? or is this something the computer is capable of recogtnizing and correctiong? i just did a 350 swap and was going to get the cop car injectors but i was told a better way to go would be to keep the stock ones i own, install an AFPR and tun the computer to push more pressure through the stock injectors, which would increase their flow rate?
Injector size increase is pretty close to CID increase. I would think the 350 injectors should be OK at former fuel pressure. 02 sensor feedback should correct A/F. I believe you may need a 350 knock sensor and I will guess a 350 ignition module? I dont believe a VAFPR will work with stock ECU. Did not for me anyway. You could crank up FP so the stock injectors flow more but then you may need an upgrade on fuel pump as well.
Injector size increase is pretty close to CID increase. I would think the 350 injectors should be OK at former fuel pressure. 02 sensor feedback should correct A/F. I believe you may need a 350 knock sensor and I will guess a 350 ignition module? I dont believe a VAFPR will work with stock ECU. Did not for me anyway. You could crank up FP so the stock injectors flow more but then you may need an upgrad on fuel pump as well.
Also im guessing from what you said, In regards to the original question of the thread, that no you could simply not switch out 305 injectors for 350 injectors without tuning the computer to know that it has bigger injectors?
Quote: "Also im guessing from what you said, In regards to the original question of the thread, that no you could simply not switch out 305 injectors for 350 injectors without tuning the computer to know that it has bigger injectors?"
As far as tuning the .bin, yes that is always most desirable. B4 one does that you should buy(Moates) or construct a ALDL cable and datalog BLM data. The increase in size of engine and the injector size and fuel pressure are all indentified in a calculation for BASE Pulse Constant. That is placed in .bin. BUT the increase in CID is 13%. the increase in injector(55 to 65) is 18% so the ecu will deliver a bit too much fuel without you correcting in .bin. I would say choke, cold running under 160F coolant, pumpshot, and PE will be a bit rich. CL will be OK.
Car: 1991 camaro RS
Engine: 408 Stroker
Transmission: 4L80e
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
hmmm i went and replaced my stock 305 injectors to cop car injectors and wen i try to crank the motor the injectors are like inconsistent instead of a steady flow of gas , they re like flikering and i have to keep the pedel to the floor so the car wont shut off.
and this is for a stock 350
sorry for the thread jaking
but i need help asap
i have used a lots of components from a 350 on a 305 tbi. like map sensor cap n spark plug wires and the car ran fine.i took my injectors from an old suburban the tbi was the same set up.i dont know much about the cop injectors except there probably going to use more fuel pressure from the pump then the stock 305 has to offer witch is only 9-13 psi.if the car ran fine before i woud switch back n make shure you didn't get any bad gas in there. n did you have any problems with it before chang?
I just switched my injectors on my 350, from my old 305 ones. I swapped the whole pod though, including the 350 regulator, now i dont know if regulators run at different rates, but my car runs fine, its a little bit stronger, but i also have the stock 305 chip, im still trying to find out if this setup is okay to run, or if i should change something, but you might have gotten a bad set of injectors, maybe your injectors wires are messed up. What kind of chip are you running in your car?
