GM performacne 350/290 HP
Car: 1990 Camaro RS
Transmission: automatic
i have a 1990 RS with a 305 tbi
i want to swap it out for a 350
can i get this motor, and an eldebrock preformer tbi intake manifold, and keep my tbi setup, and just get a bigger tbi, like the holley 670.
Or is this crate engine for carb only?
Also same question, different engine. The 350/330 HO run with GM TBI vortec intake manifold. can i keep the tbi or not?
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: GM performacne 350/290 HP
For a straight-up swap that you can take all of your old parts off and put them on the new engine, this is a good candidate:
http://www.rebuilt-auto-engines.com/...33108103304.58
And it's a good deal ... price and warranty. And it is a straight-up replacement for your motor, only with the bigger displacement of the 350.
That 350/290 is an older-style 350 that is intended for carb and no smog equipment.
Car: 1990 Camaro RS
so would either one of those motors work the 350/290 HP with the eldebrock tbi intake.
or the 330 HO with the tbi vortec intake.
all i wanna know is if it is possible?
Car: 91 RS
You can use tbi with any engine made for a carb as long as you can tune it and have enough air/fuel flow through the injection system.
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
https://www.thirdgen.org/forums/tbi/...-350-swap.html
everything you need to know i believe all you need are 350 injectors 350 knock sensor and 350 esc
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Thats' a Goodwrench 350, not a GM Performance 350. It's a pretty pathetic motor honestly. That 290hp is with full headers, no accessories, and at the flywheel. In a real world situation you'd be lucky to see 200hp out of it, more ilke 175.
Car: 1990 Camaro RS
so which crate motor would you go with Infernal Vortex? What are my other options here
does anybody know how much horsepower that L31 has? and would that be a better way to go?
Car: 1983 G20 Chevy
Transmission: 4L60
Enough to make a 5,800 lbs van run like this
http://youtube.com/watch?v=WydwLghk_yw
or a much lighter C1500 truck do this
http://youtube.com/watch?v=A8G_Sx_VVcg
Tbi can be very versitle if you learn how to tune. I never tuned using the stock ECM or PCM, but using the EBL (uilt 383 stroker) has been pretty simple so far, but far from plug and play.
If you want good power and economy, do ALOT of reading on these forums for tuning and you can utilize TBI. If you want plug & play get a 5.3 like sugested above.
