Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?
Old 07-30-2008, 12:03 PM
simpson36's Avatar
Impossible! That's what I've been hearing ever since I got my Crossfire a few years ago.
Crossfire heads and manifold get a lot of bad press, but the fact is that the tiny 4 banger TBs at 46mm and 525CFM (for the pair!) . . are the biggest restriction.
Here's how to get rid of it. This is not theory, BTW, these are ON the car and working pefectly with the stock ECM and the car no longer runs out of steam over 3,000 RPM!
Here is third prototype pair:
Secret sauce . . new custom throttle plates:
Mounted up:
Do the Dew:
That's a live shot. These guys score a total deviation of 1/4" . . I really didn't think that was possible. Performance is outstanding. When I get more time, I'll show you how I made these guys.
Old 07-30-2008, 02:09 PM
Ronny's Avatar
Re: Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock
how is this fore a manifold to replace CF?
Did that get the wheels turning???
Old 07-30-2008, 05:23 PM
simpson36's Avatar
That's purdy.
I could do the harware and even a progressive linkage . . . Hmmmm
Wonder if EBL can run three injectors?
Or SIX . . hey if we're going insane, may as well go all the way, right ?
I once had a 6x2 manifold for a 348 chevy motor (predesessor to the 409). Had no carbs on it, just 6 big holes staring at you. It was one of those kinds of things that you don't dare use, you just 'HAVE' if for a few years and then trade it for something (in my case, front runing light bezels for one of my '58 Impalas.)
Old 08-02-2008, 05:42 AM
simpson36's Avatar
Here are the second set of prototypes going on the test car.
Here is the stock Crossfire manifold coming off:
And the new Ported Crossfire manifold going back on:
I shipped out the TBs already mounted on the lid and pre-balanced, but the pods had to be mounted up:
Here is the completed install, ready for the road test:
Old 08-04-2008, 11:31 AM
Ronny's Avatar
Yes EBL can run multiple inj's. Needs to be ordered as such or sent back to RBob for mod. That manifold appears low profile as well. Could use stock CF air cleaner?
Old 08-04-2008, 12:23 PM
simpson36's Avatar
Yep, I knew EBL can run multiple injectors, I remeber reading is could drive 4 injectors, but I don't recall that is can run THREE specifically, and particularly if they could be progressive. That would be fun to play with.
Not sure which manifold you're referring to. The crossfire manifold in the pics would use the stock air cleaner. There is no change in the height with any of the mods.
Old 08-04-2008, 01:28 PM
Ronny's Avatar
I believe it is batch fire all at once. not sure if 3 or 4 would make a difference. The question of 4 came up before and the ans I believe was yes. It will fire 8 and run port fuel injection setup.
Old 01-24-2014, 08:22 AM
Hquin53's Avatar
Hi, how I can get gasket for cross fire fuel injection manifold like in picture #4? Thanks!
Old 01-24-2014, 09:09 AM
Ronny's Avatar
Try rock auto....or gmpartsdirect.com
Old 01-26-2014, 02:26 AM
kauboy's Avatar
Car: 83 Z28 Crossfire
Nice!!! Hope you get a chance to show us how you bored the throttle bodies. I followed your other articles to install reamed bushings in mine, Thanks for the detailed pics and instructions. I would also like to see how you made your "flow bench".
Old 11-05-2014, 01:17 PM
tunatrky's Avatar
Car: 83 Firebird Trans Am
Engine: 305 LU5 Crossfire Injection
Bump, what ever came of this?
Old 11-05-2014, 02:10 PM
Ronny's Avatar
Send him a PM. He does extraordinary work.
Old 11-06-2014, 05:57 PM
82tarecaro's Avatar
I think he stopped doing Crossfire stuff. I had contacted him a few years ago about my throttle bodies and he told me as such. It is possible he may have had a change of heart so it wouldn't hurt to contact him.
Old 12-05-2014, 04:18 PM
kauboy's Avatar
I have a set of sleeved about 53mm throttle bodies
Old 12-10-2014, 07:54 PM
kauboy's Avatar
Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0440.jpg
Reamed throttle shaft bushings.
Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0441.jpg
Old 12-10-2014, 08:25 PM
82tarecaro's Avatar
Are you selling them? Do they have balance ports?
Old 12-11-2014, 12:32 PM
kauboy's Avatar
I may sell them for the right price. I will try to post pics later. They do have balance ports machined in.
Attached Thumbnails Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0443-640x480-.jpg   Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0447-640x480-.jpg   Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0449-640x480-.jpg   Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0451-640x480-.jpg
Old 12-14-2014, 11:21 AM
kauboy's Avatar
Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?-dscn0444-640x480-.jpg
Old 12-17-2014, 07:25 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Are you still selling them ?
Old 12-19-2014, 01:02 PM
kauboy's Avatar
I'm going to sell them. I have to figure what they're worth.
Old 11-12-2017, 07:34 PM
Stevmister's Avatar
Hey,stevmister,been while but were er Who did those Crossfire Tb.s fer Yah?! can message me ear er stevmister@yahoo.ca,Any n All lnfo wud Help! Thx Buddy!
Old 11-20-2017, 09:36 AM
Ronny's Avatar
Years back I had mine done by a member of crossfire forum . His name is Dan Plecan. I think he was in Kansas. I might have the invoice in a file. If you are interested.
Old 11-20-2017, 02:39 PM
Stevmister's Avatar
Hey! Thx fer Gettin back to Me! Seems My Build is lil late fer the ppl that had want of Makin these Cross Fires Perform,lf you can Dig Up a Name er Contact for Boring TB.s lt wud Help.Called 23 Diff PlacesAll over North merica! Actually talked with Simpson,Guy Did MOATBodies,he gave me some lnfo but,Thinkin l need machine shop to make this Apin! Any n All lnfo wud be Appreciated!
Old 11-21-2017, 08:37 AM
Ronny's Avatar
I will see what I can find
Old 11-21-2017, 08:40 AM
Ronny's Avatar
dynamic crossfire solutions also bores the TB's. see site
Old 11-21-2017, 11:07 AM
Stevmister's Avatar
Thx!,Dynamic went outa Business year ago! Was one of the places l tracked down,Guess l.ll Keep lookin!
Old 11-21-2017, 02:01 PM
82tarecaro's Avatar
One of the owners still checks in here from time to time. I think his name is Buccaneer or something like that. He may still do some business. I know he still had some parts left.
Old 11-21-2017, 02:03 PM
82tarecaro's Avatar
Here you go - this is his member page. Try sending him a pm.
https://www.thirdgen.org/forums/member.php?u=45857
Old 11-21-2017, 05:14 PM
kauboy's Avatar
I'm not sure who did these bought the set from a guy that was going to use it on a 383 stroker.
Old 11-22-2017, 09:44 AM
Ronny's Avatar
Cant find invoice. I am certain he is a member here or on Corvette Forum
Old 01-14-2018, 01:45 PM
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
I am here from time to time to see what going on over here. We/I don't do TBs now, but maybe in the future. That whole thing is still up in the air even after a lot of years... Sorry.
Old 01-14-2018, 06:14 PM
TRANSAM82-92's Avatar
God
I still want one of those Renegade manifolds, never got one
Old 01-15-2018, 02:14 AM
t/aws61985's Avatar
Car: 85-6 TA 85IROC 82-6 MSE 15th/83pace
Engine: Slow ones
Transmission: 700R4/T5
Axle/Gears: Weak ones
https://www.ebay.com/itm/Eddie-Motor...paAcnz&vxp=mtr
They still make them
Old 01-15-2018, 07:36 AM
KITT1983's Avatar
Originally Posted by TRANSAM82-92
God
its well worth it i have one in my Daytona 500 pace car
Old 01-15-2018, 09:04 AM
Ronny's Avatar
Renegade $550 at Summit. A Weiand single plane X cellerator $196. Add a used 7.4L TB with adapter and you may have as good performance maybe better top end. I used a Holley dual plane with 7.4L TB but hood rubbed. Hindsight I should have used the Weiand (should) clear. Actually I did(XRAM) Now I am port fuel with a Vic Jr.
Old 01-15-2018, 11:06 AM
Buccaneer's Avatar
Axle/Gears: 3.31
The manifold is still available if you are still interested until we pull the tooling. Looks like we will be bringing our old site down this week, it's been up for eight years.
Funny about manifolds, there are all kinds around, it just depends on what you are looking for or wanting to do I guess, some work better than others. One thing I can say for a fact is, that ours out performs a XRam hands down. Ben73 in Australia on the corvette forum proved that with just a XRam to Renegade swap on his 383, 84 CFI vette. He picked up 3 tens in the 1/4 mile with no other mods done including a tune change, he ran 12.20s constantly. Before the swap he ran a 12.52 I beleive one time and could never repeat that time. There is a long write-up on all that somewhere on the forum, you would have to search for it. Ben was the third person to have one of our manifolds and it was a Pre-Production casting. His was the last one to go out before we started full production.
Good luck with whatever you choose and have some fun.
Old 01-29-2018, 04:17 PM
Buccaneer's Avatar
Axle/Gears: 3.31
Our old site is still up. After talking about it, we decided to leave it up at least another year. Enjoy. Recently decide to pull it down...sorry guys.
Old 04-10-2022, 01:42 AM
KITT1983's Avatar
I'm interested in boring my spare tbis
NinjaNife
08-23-2015 11:49 AM
89-S-dime
08-12-2015 11:57 AM
marcusaw
08-10-2015 08:13 AM
3rdgenparts
08-06-2015 09:03 AM
Quick Reply: Crossfire TB bored to 49mm 690CFM, NO sleeve, HAS its balance port and use stock ECM?
