New Engine
Old Aug 3, 2008 | 08:25 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
New Engine
So my car is finally finished. I have a 92 camaro rs with a 383 tbi in it. It passed CA smog and everything. Only took about 4 months but that includes the engine swap, transmission rebuilding, and rear end getting rebuilt plus all the small issues I ran into. Ill include some pictures of the engine before it was put it. I'll have to take some more of it in the car since I had to change all the plugs again it looks a little bit different.
Old Aug 4, 2008 | 09:10 AM
kcb37's Avatar
Re: New Engine
Good to hear.
Feels good to have done that too.
Little bit harder with CA emissions too.
Old Aug 4, 2008 | 12:11 PM
ojaijohn's Avatar
Re: New Engine
What size injectors and throttle body did you choose and who did you source them from?
Old Aug 4, 2008 | 01:24 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Re: New Engine
I used the tbi unit from the 305 and put 350 fuel injectors in it.
Old Aug 4, 2008 | 09:43 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Re: New Engine
hmm....looks just like a freshly rebuilt 305, with some Edelbrock headers. good work.
Old Aug 4, 2008 | 11:13 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Re: New Engine
Which cam and cylinder heads did you use?
Gene
Old Aug 5, 2008 | 02:17 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Re: New Engine
The engine is a 383 it was made to look like a 305 for smog though.*hint* the 5.7 on the block was grinded to 5.? and then painted. The cam in it is the comp cam 12-388-4. The heads on it is World S/R Torquer. By no means does this engine make massive power it made about 295 horsepower and 400 lbs of torque.
Old Aug 5, 2008 | 02:20 AM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Re: New Engine
Here's some pictures of the block. I haven't had time to take pictures of the engine in the car but I will once I have time.
Old Aug 5, 2008 | 03:22 PM
S105.7's Avatar
Engine: L98 & L03
Re: New Engine
where does CA stand on the Vortec L31 heads? last i know it wasn't legal, even if you retained the EGR. i guess neither the GMPP intake, nor the heads carry an EO #.
Old Aug 5, 2008 | 04:34 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Re: New Engine
As far as I know Vortec heads aren't legal in CA unless the car came with them. Otherwise you have to update all of your smog to a car that came with those heads. I haven't seen any with a CARB sticker or anything. I just got my registration sticker on today I'll take some more pics of the engine in the car. Looks a little difference since I had to change all my spark plug wires again.
Old Aug 5, 2008 | 04:43 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Re: New Engine
Some pictures of the engine in my car.
Old Aug 5, 2008 | 04:52 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: New Engine
Nice job, hope I can do the same one day.
At wat rpm s did u get tose numbers?
Old Aug 5, 2008 | 08:10 PM
dekoy411's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L
Axle/Gears: Stock
Re: New Engine
It was at 4500 rpm. I haven't gotten my transmission adjusted yet to shift higher.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
