Engine trouble !!
Old Aug 10, 2008 | 01:53 AM
Stu's Firebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 305 5.0L V8
Transmission: Stock
Engine trouble !!
All of a sudden today my firebird just started acting wierd! When I sit idle it just dies!! I have to keep it rev'ed up just to keep it running. The temp. is fine, also the oil and voltage are fine too. What could it be?? Please help!
Stuart
Old Aug 10, 2008 | 04:07 AM
kcb37's Avatar
Re: Engine trouble !!
How old is your fuel filter?
Do you have an engine light?
Could be something like the IAC, or TPS.
Does it do it cold, hot, or both.
If it only does it when it's hot it could be the ignition control module.
How old are the spark plugs and wires?
How about the cap and rotor?
Old Aug 10, 2008 | 11:20 PM
Engine: 305 5.0L V8
Transmission: Stock
I just changed the fuel filter when I changed the spark plugs, engine light is on. also just changed the rotor and wires maybe a month ago. But tried to start this morning before work and it didn't do anything.
Old Aug 10, 2008 | 11:55 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
First figure out what code has been stored that caused the check engine light to come on.
First figure out what code has been stored that caused the check engine light to come on. Once we can determine what code it is we can go from there.
Old Aug 12, 2008 | 06:33 PM
Engine: 305 5.0L V8
Transmission: Stock
It was the throttle body gasket!!!!!!!!!!!!!! a little thing, a big problem!!
Old Aug 25, 2008 | 01:08 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
could also be a sign that your ICM is going bad or your running way rich which happens to me .
backtothe80s
Sep 5, 2015 12:39 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
