Fuelpump
Old Aug 27, 2008 | 12:35 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Fuelpump
Hi!
Can you have a tpi fuelpump insted of the tbi one at a tbi motor,or will it run rich?
Old Aug 27, 2008 | 12:39 AM
Stephen's Avatar
Car: 87 GTA
Re: Fuelpump
TPI systems run at roughly double pressure than TBI. So no..you can't run a TPI pump. Sorry.
Old Aug 27, 2008 | 02:56 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Re: Fuelpump
Ok
Thanks!
Old Aug 27, 2008 | 04:38 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Fuelpump
Originally Posted by Firebird sweden
Hi!
To run a TPI fuel pum you must make the FPR adjustable (AFPR) and probably put a little stiffer FP spring in to keep it at 11.5 - 13 psi.
If you dont do any upgades that will require more fuel, it is better to use the stock TBI pump.
If you do a LT1 cam swap with full exhaust you will need a TPI pump, AFPR, top dawn solution's 20psi FP spring and tune it correctly to feed 250-260hp @4500rpm.
Old Aug 27, 2008 | 04:47 PM
Ronny's Avatar
Re: Fuelpump
Your stock FPR should bleed off the greater flow capacity of the TPI pump and maintain the pressure it was set to initially(12 lbs). I would swap in the TPI pump if you plan on any engine enhancements down the road. I would also make the FPR adjustable and add a FP gauge. If intentions are to run stock then the TBI pump should be just fine.
Old Aug 27, 2008 | 07:25 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
Re: Fuelpump
You took the words right out of my mouth... a few months ago, I switched my TBI pump out with a 255 lph fuel pump by Edelbrock intended for TPI applications and the excess fuel does exactly what you stated and I installed a fuel pressure gauge to assure that all stays well. The reason for the swap of pumps is that I am currently building a 383 stroker LT1, so I definitely will be needing the extra fuel / pressure . Your stock FPR corresponds with your ECM only letting the required fuel out, no more, no less.
Caspar
Jun 19, 2016 11:19 PM
Theking
Feb 15, 2008 02:43 AM
305RSlc
Aftermarket Product Review
Oct 1, 2007 09:25 PM
The White Knight
Aug 11, 2007 09:16 PM
Z28_from_Europe
Jun 6, 2004 03:05 PM
