I Need Help. Won't Run
Old Sep 7, 2008 | 01:44 PM
Whips89RS's Avatar
Car: 72 Malibu, 89 RS & 04 Z71 extended
Engine: (2)350's & 327
Transmission: auto/T5
Axle/Gears: 4:11, 2:73 & 3:73
89 RS 305 converted to 350 last year, read the threads, did all the correct swaps and ran great for a year. This summer I swapped over from auto to t5. Everything went great for a week, drove it back and forth to work. I was on my way home from a cruise night, pushed the clutch in to downshift and it stalled. Wouldn't idle or run after that. It cooled down a bit and I nursed it home, barely. it seems to run a little better when cold but still won't idle. As it warms it starts coughing and skipping and barely running. I got a code 44. if I disconnect the MAP it runs smooth and will idle but will not run if I put a load on it. I can cruise around like this at low rpm's if I ease into the gas. I haved checked all the vacuum lines and connections on everything else. The cat is hollowed out so I know that isn't clogged. It has a new O2 sensor. I'm looking for help as to where i should start or go from here.
Old Sep 7, 2008 | 10:02 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
Re: I Need Help. Won't Run
Make sure you have vacuum to the MAP sensor. If so replace it. I didnt see where you were from but I have a few laying around if you want on.
camaro11j
Sep 19, 2018 08:49 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
justin57
Aug 20, 2015 07:05 PM
Bull86
Aug 10, 2015 05:43 PM
