plugs and wires?
plugs and wires?
in your opinion, what are the best plugs and wires that you can buy to make more power and have the best performance. I need to re do my plugs and wires and am looking for the vest to install. Any advice?!?!
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: plugs and wires?
much better than most high dollar plugs . wires are a different story , ( good time to do total ign. sys. upgrade if you can afford it ) OEM type wires for the most part are carbon core . carbon core starts to degrade from date of mfg. . you could by a new set that has been in a warehouse/parts store shelf for several years . not a good thing . there are many after market wires that are great . M.S.D. , Acell , Taylor to name a few . i have all M.S.D. wires , coil , cap , & rotor on my car with stock dizzy . very happy with my set up . good luck . Joined: Feb 2006
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
AC Delco all the way for plugs. I have used Taylor and Mallory and they are both great for wires and the rest of the ignition.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Borg Warner Select spark plug wires, part number #8383 (or 8833?) for an 87-95 Chevy Truck TBI 350. They're 8mm instead of our stock 7mm, they bolt right in, they're inexpensive, and they work!
Car: 1992 Z28 L98 G92
Engine: 5.7 350 B2L
Transmission: 700 R4
Car: check
Engine: check
Transmission: check
Yep, Pep Boys out here, or Checkers/Schucks/Kragen has them too.
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
