1.6 roller rocker installation
Old Nov 11, 2008 | 05:43 PM
95chevyTBI's Avatar
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
is it hard to install roller rockers to a 95 chevy tbi truck? does it require special tools?
Old Nov 11, 2008 | 05:50 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: 1.6 roller rocker installation
easy as can be..........just like pre center bolt rockers
Old Nov 11, 2008 | 06:00 PM
95chevyTBI's Avatar
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
these are the only ones i know that are good. does anyone know of any other good ones that are cheaper?
http://store.summitracing.com/partde...6&autoview=sku
Old Nov 11, 2008 | 07:13 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i'm sure those are good . do you need them for a truck ? thats up to you . anyway back to my thought . maybe this can save you some bux . i was checking prices on comp cams roller tip rockers , pn# 1416-16 . northernautoparts $145.99 , advanceautoparts $229.99 , ( an old summit catalog ) $285.95 . i have bought stuff before from northernautoparts before and always saved some bux . same brand name parts , better prices . just my thoughts , we all need to save money where we can . good luck .
Old Nov 11, 2008 | 10:04 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
this northern autoparts got a website tom?
Old Nov 11, 2008 | 10:09 PM
89RS_82Z's Avatar
http://www.northernautoparts.com/
i'll help you out Tom...... hope you have a safe trip tp FLA, see you at our dec meet i hope
Old Nov 11, 2008 | 10:10 PM
zap's Avatar
zap
Be prepared to open up the push rod holes with a 3/8 drill bit for clearance.
If your real careful it can be done without pulling the heads.
Old Nov 12, 2008 | 02:00 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
wow opening up pushrod holes does not sound fun at all any good 1.6 rockers that dont require one to do that?
Old Nov 12, 2008 | 08:52 AM
Doc_G's Avatar
Car: 87 Trans Am
thanks for the link, ordered myself a print catalogue.
Old Nov 12, 2008 | 09:12 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
No. That's the nature of the 1.6 ratio; the pushrod is moved closer to the rocker fulcrum.
Old Nov 12, 2008 | 10:03 AM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Can I ask a real quick question: What do 1.6 roller rockers net you over stock? I'm not asking about power gains, I'm asking about how they affect performance.
Old Nov 12, 2008 | 10:11 AM
86LG4Bird's Avatar
With a stock cam that is severly undersized for the engine, like the peanut cam, they are worthwhile. Probably at least a tenth in the 1/4 mile and 1+ mph, equating to about 10 hp. The torque/hp boost happens in the mid and upper rpm range, so you won't fell it SOTP.
If you're already running the optimum camshaft, they won't do anything for you.
Old Nov 12, 2008 | 10:29 AM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Thanks.
Does that mean that 1.6 roller rockers allow the camshaft to apply more lift so the valves can open more?
Old Nov 12, 2008 | 10:30 AM
86LG4Bird's Avatar
Yes.
Old Nov 12, 2008 | 10:31 AM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Thanks, that will be really useful.
Old Nov 12, 2008 | 08:03 PM
ojaijohn's Avatar
Would switching to 1.6 rockers affect an engine's ability to pass emissions testing? I'm about to install a Smeding Performance 383 with a mild cam and 1.5 rockers that's designed to be California legal. I know it's capable of more than it's rated 310 hp but don't want step over the line on emissions.
Specs are: Valve lift .414 / .428
Duration: 261/263
Duration at .050" 194 / 198
Lobe center: 111
Ground 5 degrees advanced
Old Nov 13, 2008 | 06:51 AM
86LG4Bird's Avatar
OMG! That almost sounds like a stock L31 cam in a 383!
What a shame. You'll get no more performance out of that 383 than a bone stock L31 Vortec engine.
If you're already stuck with that engine, then yes by all means, install some 1.6 rockers on it, and of course make sure you have the correct springs and retainers to permit the extra lift. It will have no problems passing CA emissions.
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
