open element raised or flat?
Old Nov 19, 2008 | 08:19 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
I am planning on changing to an open element air cleaner. I have read that some people have clearance issues with the dropped design, so my question is what what would be better a flat designed base or a raised design? will the raised base have any hood clearance issues?
Old Nov 20, 2008 | 01:02 PM
Ronny's Avatar
Re: open element raised or flat?
For me the drop struck the throttle shaft lever. I used a 1 inch spacer with a flat base.
OBTW I have one for sale in classifieds with a KN AC. Better than that I have a carb bonnet as well 4 sale that can be ducted so as to allow cold air set up.
Old Nov 23, 2008 | 03:09 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have a flat base, I removed the gold spacer ring on top of the TBI unit.
Old Nov 23, 2008 | 08:52 PM
J-money's Avatar
I went ahead and went with a Proflow flat base element from summit racing, only cost like 25$ hopefully I wont have any problems with it touching the coil.
Old Nov 23, 2008 | 09:56 PM
krisb410's Avatar
It's the drop base ones that you have to worry about touching the coil, not the flat base.
Old Nov 23, 2008 | 10:13 PM
J-money's Avatar
what I've always wondered is if the drop base touches the coil then why do some people get it if you have to get a spacer to make it work. is there some other advantage to having a drop base?
Old Nov 23, 2008 | 10:19 PM
krisb410's Avatar
No, it's actually better to get a flat base. Because you remove the restrictive gold spacer ring. With a drop base, you have to keep that spacer ring. Although, a drop base would allow you to use a TBI spacer, (the one that goes under the TBI unit), or a taller intake I suppose.
Old Nov 23, 2008 | 10:23 PM
J-money's Avatar
Oh okay well in that case I'm glad I went with a flat base then. thanks
Old Nov 27, 2008 | 11:46 AM
J-money's Avatar
ok so I've got my flat base air cleaner installed but I noticed at first it was really close to the coil wires so my question is how close is to close? they arent touching but not far from it. as for now i just left the gold ring on there to raise it up but that looks kinda funny.
I'm not sure how to upload the pics I've taken of it tho.
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
NiG
Sep 7, 2015 11:25 PM
luvofjah
Sep 3, 2015 07:08 PM
