Idle adjustment
Old Dec 9, 2008 | 10:41 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Idle adjustment
May seem trivial but is there any way to adjust the idle of a TBI unit without dealing with the computer?
Old Dec 10, 2008 | 11:34 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Idle adjustment
There should be a torx screw (probally behind a aluminum plug) on the front side of the TB. By the linkage assembely.
Old Dec 10, 2008 | 11:47 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: Idle adjustment
pic by any chance?
Old Dec 10, 2008 | 12:15 PM
Engine: 5.0 TBI
Re: Idle adjustment
I don't have a pic on hand. If no one has a pic up for you in the next couple hrs. I will go home and get one for you and post it. Also why are you needing to adjust the idle?
Old Dec 10, 2008 | 12:34 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: Idle adjustment
The idle is just above where i would like it to be. When warm it idle's around ~900-1000rpm. Just want to drop it a bit, nothing crazy.
Old Dec 10, 2008 | 01:06 PM
Ronny's Avatar
Re: Idle adjustment
Idle speed is controlled by the ECU. The IAC devise allows a controlled vac leak by what is called steps. Lets say 900 rpms requires 20 steps out of 200 possible. It opens the air inlet slightly. Now you remove the safety on screw and back out screw. Butterfly closes a tad. ECU sees idle rpm is dropping and we need to maintain 900 rpms so it opens IAC allowing more air at 30 steps and back to 900 we are(stall saver). Now if you want to drop idle it appears you need to command like 15 steps with a change in .bin OR commmand to zero steps for IAC which might be 500 rpms and then use the throttle screw to set at 800(like I do).
Old Dec 10, 2008 | 05:22 PM
Engine: 5.0 TBI
Re: Idle adjustment
Ok so here is the pics.
http://www.flickr.com/photos/31244464@N04/3099136306/
http://www.flickr.com/photos/31244464@N04/3099140006/
http://www.flickr.com/photos/31244464@N04/3099138114/
Oh.... And if you can figure what problem i have, that would be great.
Old Dec 10, 2008 | 06:14 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: Idle adjustment
Those pics are a great help.
Let me guess, the ol' I was working on my car with the hood off and it started to snow deal?
Old Dec 10, 2008 | 06:25 PM
Engine: 5.0 TBI
Re: Idle adjustment
Close.... The whole Previous owner hit a bear , and now i get to fix it deal. But at least i get to save 1 more third gen.
Old Dec 10, 2008 | 06:32 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Re: Idle adjustment
Keep 'em alive
Old Dec 10, 2008 | 06:44 PM
Engine: 5.0 TBI
Re: Idle adjustment
I am trying to keep her alive. lol. But she is being tempermental at the current time.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
