Very Very Strange Problem with my 305 TBI Trans Am
Old Dec 21, 2008 | 05:09 AM
BustaZz's Avatar
Hello, I have the following problem with my car 305 TBI and as I drive the car stops suddenly not even know that you extinct until you feel your hard drive and see no indication "Service Engine Soon" The other I often do when the switch from direct to the rear or by direct rear engine stops again ... Do you have any idea where I come problems
Old Dec 21, 2008 | 06:40 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Very Very Strange Problem with my 305 TBI Trans Am
HUH????? What???? If you could re-post that in a way that some one could understand. Then someone might be able to help you. .... And if you are a spammer you should be
Old Dec 22, 2008 | 01:07 PM
Ronny's Avatar
He is talking in code. remember Barbra Bilingsley in Airplane?
From Airplane! (1980)
Randy: Can I get you something?
Second Jive Dude: 'S'**** butter layin' me to da' BONE! Jackin' me up... tight me!
Randy: I'm sorry, I don't understand.
First Jive Dude: Cutty say 'e can't HANG!
Jive Lady: Oh stewardess! I speak jive.
Randy: Oh, good.
Jive Lady: He said that he's in great pain and he wants to know if you can help him.
Randy: All right. Would you tell him to just relax and I'll be back as soon as I can with some medicine?
Jive Lady: Jus' hang loose, blood. She gonna catch ya up on da' rebound on da' med side.
Second Jive Dude: What it is, big mama? My mama no raise no dummies. I dug her rap!
Old Dec 22, 2008 | 04:08 PM
Engine: 5.0 TBI
Old Dec 25, 2008 | 08:12 AM
BustaZz's Avatar
Hi, I have the following problem with my car, 305TBI.
As I drive the car stops suddenly, a light "Serive Engine Soon" lits and the steering wheel gets locked. The other problem I have is when I change into Reverse Shift the car engine stops and vice versa when I go from Reverse Shift to 1st Shift the engine stops again. Any ideas of what might be causing the problem?The Gearbox is automatic.
Old Jan 11, 2009 | 10:58 AM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
you need to check for vacuum leaks. have you recently performed a tune up? If not it might be time. remember to set the base timing.
Old Jan 11, 2009 | 01:06 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
as for the Service Engine Soon light, you can check for trouble codes but i'm not sure if this is understandable for you:
https://www.thirdgen.org/service-eng...ht-error-codes (btw it's pin 5 and 6 you need to short)
if you can't understand, i'll try explaining it to you
Old Jan 11, 2009 | 03:27 PM
Engine: 5.0 TBI
Sounds like you might have some tranny issues. I would re-post this in the transmission/drivetrain section, you will get more help there.
Old Jan 11, 2009 | 03:48 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
ok the check engine light is coming on when the car is stopped is normal. because when the ignition is on and car not running the check engine light is on. Now your problem sounds to me like a transmission lockup control problem.
Old Jan 12, 2009 | 04:14 PM
BustaZz's Avatar
OK Thank you all for answers ! First sorry for my english but I hope you will understand me what i want to tell you
First I do diagnostic with blink code but "service engine soon" say only code "12" what mean that , it is all ok i think?
Other you say maybe its coming from vacuum ? What i must do replace all vacuum hose`s ?
Best Regards all who help me !!!
Old Jan 12, 2009 | 04:25 PM
Ronny's Avatar
For me code 12 is no distributor reference pulse to ECU. flash - flash flash.
Old Jan 12, 2009 | 04:43 PM
BustaZz's Avatar
Ronny what you mean ? What i must replace when i have code 12?
Old Jan 12, 2009 | 04:55 PM
Ronny's Avatar
If your code 12 is same as my code 12(5550 ECU) then your ECU is not seeing DRP. Service manual says can happen when aldl is grounded ign on engine off. OR determine why the distributor is not communicationg with ECU.
Old Jan 13, 2009 | 08:48 AM
BustaZz's Avatar
Ok Guys Tomorow I will replace all hoses ... But i have one more question, What is Idle RPM normaln when car @ Parking and @ Drive ? My is 550 i think that`s not normal ?
Old Jan 13, 2009 | 10:14 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Code 12 has two meanings, depending on whether you're checking your codes with the engine off or with the engine on.
"Normally," codes are checked with the engine off and the key in the on position, so I'm guessing that's how you're checking it. And in that case, it's normal to get code 12. It should always show-up. It simply lets you know the diagnostic system is working. Any other stored codes will follow code 12. But if 12 is the only code you're getting, over-and-over, and no other codes follow it, then code 12 is not a probem, and there are no other trouble codes stored. So your problem probably isn't diagnostically-related.
And when you're light comes on when the engine dies, that's not a problem either, that's normal, as someone already mentioned. And your code 12 is not a result of that.
But if you're checking for codes with the engine running, and you get code 12, then yes, it's distributor/ECM related problem, which could be just a connection problem at the distributor.
Old Jan 13, 2009 | 10:32 AM
BustaZz's Avatar
Thank you MATE ... I Checked codes when my engine is off ... How i can check codes when engine are running , i gues its similary metod when engine off ? And do you know what is Normal RPM for 305 TBI on Parking Gear and Drive Gear ?
Old Jan 13, 2009 | 10:38 AM
Ronny's Avatar
I say lowest RPM car will idle well at in gear. Idle typically is set by IAC steps in .bin. I did it differently and zeroed out idle IAC steps and used the throttle stop screw. My datalog will show malf codes while engine running. Hopefully there are none. I check every datalog.
Old Jan 13, 2009 | 10:51 AM
LAFireboyd's Avatar
Ok, so you're checking it with the engine off, and that's the normal way to do it. And code 12 is the only code you're getting, and that's also normal(and good). That means your diagnostic system is working properly. And no other codes means there are no problems that are diagnostically-related.
It's probably a transmission problem, like other people have mentioned.
But to check for codes with the engine running, FIRST you start the engine, and SECOND you connect your jumper to the aldl port. Don't connect before starting the engine. Then just read the flashes like you would normally read them.
I'm not exactly sure what the rpms should be at idle. Mine tends to run around 600-700, and that seems ok.
Old Jan 13, 2009 | 11:17 AM
BustaZz's Avatar
Mate i check now codes when my engine running and I receive three codes "42" "44" and maybe "45 or 46 im not sure" where i can see what is problem ?
THIS CODES I RECEIVED WHEN ENGINE IS RUNNING !!!
WHEN ENGINE IS NOT RUNNING I RECEIVED ONLY "12"
Old Jan 13, 2009 | 12:58 PM
ownor's Avatar
Engine: LS1 / L03
what is the difference between the codes that are displayed with engine off vs. when engine is running!?
you can find the trouble codes for the 5.0 TBI here:
http://www.troublecodes.net/GM/88-93_50E_tbi.shtml
Old Jan 13, 2009 | 02:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You can't flash the codes with the engine running. What the ECM is doing is reporting whether the O2 sensor is reading rich or lean.
While in drive an idle speed of 550 RPM is correct. In park/neutral it is common for the idle speed to increase a little.
RBob.
92camaroJoe
Jul 29, 2023 07:57 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
