Emissions??
Old Dec 27, 2008 | 05:57 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
Emissions??
I have a 89' 305 v8 TBI Camaro, the last owner of the car told me that the car didnt pass emissions because it was giving off to much oxygen...he told me that in order to pass i just needed to install new converters...does anybody know if this is true or not, or what the problem could be???
Old Dec 27, 2008 | 06:02 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Emissions??
what state, and to much oxygen LOL i think he ment Co2
Old Dec 27, 2008 | 06:12 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: Emissions??
LOL I never thought about that! Im in Georgia...LOL
Old Dec 27, 2008 | 06:23 PM
89RS_82Z's Avatar
Re: Emissions??
you must be near ATL
i would go to one of the emission check places that do it for a charge (i seen the everywhere when im up there) have them check it and tell you how bad it is, get the results and post them up....more than likely a new cat will fix the problem, or maybe your air pump into the exhaust aint working as well as it should, but thats what i would do get it checked out and see where you stand, and go from there, no use in throwing parts at something when you are no 100% sure what the test results are
Old Dec 27, 2008 | 06:34 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: Emissions??
Thanks, would you happen to know why my car just shuts of and locks up like 5 seconds after burning out or sliding around a corner, my timing is off really bad... could it be that??
Old Dec 28, 2008 | 01:03 AM
89RS_82Z's Avatar
Re: Emissions??
does it do it when you are low on gas, you could be slinging all the gas away from the pickup
Old Jan 7, 2009 | 04:30 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: Emissions??
lol mine does that also but i think im low on gas when i do that lol.
Old Jan 7, 2009 | 05:36 PM
doctorcad's Avatar
Re: Emissions??
Timing has a huge impact on emissions. If have too much advance you will fail on NOx, and maybe HC.Before you spend money on new converters, try this:
Assuming you have a timing light, check for the factory base timing on the sticker under your hood, disconnect the timing connector and adjust the distributor to get it right.
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
