Probably did something wrong
Old Jan 1, 2009 | 07:34 PM
dasferret's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock open 2.73's
I have a dead stock 92 camaro RS and did the ultimate TBI mods in a spare TB I had laing around. I smothed the entire top of it and spaced the injectors up with 1/4" long peices of hard tubing. I put this on my car and it gave me a code 33 and when I gave it 2/3 throttle or more it was running lean. After adjusting everything and testing all sensors, I gave up and put the stock unit back on. Started the car and everything was perfectly fine. What could be the problem here? If need I might be able to get pics and can def give casting numbers on the TB's.
Old Jan 2, 2009 | 02:36 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Probably did something wrong
Did you make your fuel pressure regulator adjustable ?
Old Jan 2, 2009 | 10:12 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
is your pod spaced too high letting the fuel get on top of the tbi instead of spraying down into the tbi.and is it a 305 or a 350 pod?check those things out.also check for vacuum leaks..
oh yeah "Been there done that"
Old Jan 2, 2009 | 10:44 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Please correct me if I am wrong, but I think code 33 usually means that the MAP sensor voltage is too high (low vacuum) for 5 seconds when throttle opening is less than 4%.
CIRCUIT DESCRIPTION :
The Manifold Absolute Pressure (MAP) sensor responds to changes in manifold pressure (vacuum). The ECM receives this information as a signal voltage that will vary from about 4.5 - 4.8 volts at idle to 4.0 - 4.5 volts at wide open throttle. The "Scan" tool displays manifold pressure in volts. Low pressure (high vacuum) reads a low voltage while a high pressure (low vacuum) reads a high voltage. If the MAP sensor fails, the ECM will substitute a fixed value and use the throttle position sensor (TPS) to control fuel delivery.
TEST DESCRIPTION : The numbers below refer to circled numbers on the diagnostic chart.
1. A Code 33 will set when:
1. MAP sensor signal is too high, (pressure greater than 68 kPa (10.0 psi) or less than 9.0 inches of Hg.), for a time greater than 5 seconds.
2. TPS less than 4%.
3. Engine misfire or a low unstable idle may set a Code 33. Disconnect MAP sensor and the system will go into backup mode. If a misfire condition remains. See: Related Tests and Information
2. If the ECM recognizes the low MAP signal, the ECM and wiring are OK.
DIAGNOSTIC AIDS :
1. With the ignition "ON" and the engine not running, the manifold pressure is equal to atmospheric pressure and the signal voltage will be high. This information is used by the ECM as an indication of vehicle altitude and is referred to as BARO. A comparison of this BARO reading, with a known good vehicle with the same sensor, is a good way to check the accuracy of the problem sensor. BARO readings should be similar within +/- 0.4 volts.
2. A Code 33 will result if circuit 455 is open.
3. See: Symptom Related Diagnostic Procedures\A - E Charts & Related Test Procedures\C Charts\Chart C-1D Manifold Absolute Pressure (MAP) Output Check to test the MAP sensor.
4. If a Code 33 is intermittent, See: Symptom Related Diagnostic Procedures\Intermittent Condition
Old Jan 2, 2009 | 10:46 PM
dctrumpet's Avatar
Hope this helps!
Attached Thumbnails Probably did something wrong-code-33.gif   Probably did something wrong-code-33-part-2.gif
Old Jan 2, 2009 | 10:49 PM
dctrumpet's Avatar
Check TPS, IAC on the TBI that caused the issues and just a quick thought... Was the vacuum line to the back of the TBI (MAP sensor port) connected well with the newer TBI?
Hope this helps you out.
Old Jan 6, 2009 | 03:01 PM
dasferret's Avatar
Car: 1992 Camaro RS
Didn't make fuel pressure reg adjustable, injector pod was stock unit off car and was reason I didn't make it adjustable cuz I didn't have another that would work. All lines where connected and checked, double checked and triple checked all other items. In fact used all items off the modded TBI on original one and with no adjustments car ran fine. Only thing I can think of is that the pod was too high.
Old Feb 9, 2009 | 09:48 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Got the same exact problem now lol. Modified my TBI and now its running like crap. Id say about 30% of my power is magicaly gone. Didnt see no fuel up top, but would adding that spacer to the pod do this ? My car is also more quiet now, its not as loud, shifts harder for some reason, but acts realy weak and the rpms dont go up fast like before, they kinda just hang like its burning out but its not.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
