305 to 350 Questions
Old Feb 11, 2009 | 04:51 PM
cnnbrunson's Avatar
Car: 90 RS'
Engine: 305 TBI
Transmission: Automatic
I have a 90' camaro rs and have put a 350 in it. Do i need to change the computer, injectors, knock sensoer, and the esc mod?
Old Feb 12, 2009 | 08:58 AM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Re: 305 to 350 Questions
I'm not 100% on this, but I did this swap in my '91 truck, and it worked just fine. You need a 350 chip for the computer, but can keep the same computer and you also should upgrade the injectors. The 350 injectors flow more fuel to feed the larger engine. Everything else should be the same, as far as I know.
Old Feb 12, 2009 | 09:21 AM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
you correct you will need to swap all that out the computer will not feed enough feul for the motor it for the 305 and the injectors on the tbi are for a 305 not the 350 and yes the knock sensor and esc go to the junkyard look for a caprice with the the cop package and all you need will be there as for you harness and pulley everything like that will bolt right back on
Old Feb 12, 2009 | 11:57 AM
Engine: L98, LG4
Hmmm...maybe THAT's why the motor never ran quite right...I didn't change those other two items.
Old Feb 12, 2009 | 03:30 PM
Ronny's Avatar
Injectors? Maybe not if your fuel pump can handle a higher fuel pressure. I would try the old injs and upgrage to a TPI pump and add a FPR.
ESC probably.
Chip needs to be for your tranny.
Cop car chip would be OK for auto trans.
Old Feb 12, 2009 | 03:42 PM
Engine: L98, LG4
I believe the 305 to 350 tbi swap sticky will answer all of these questions. I just looked at it. Turns out that the truck esc is the same in 305 and 350 applications, but not in car applications. The knock sensor, however, is not.
Old Feb 12, 2009 | 03:47 PM
Ronny's Avatar
The harmonics of the knock sensor must be sufficently different 350 vs 305 to require a diif part #. the KC on my two stroke 700cc is very sensitive. In fact during break in went off frequently(KC light) after break in was a non issue. Perfectly matched to engine now.
Old Feb 12, 2009 | 06:42 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
ESC probably.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
