i cant get my motor to fire
Old May 5, 2009 | 09:13 AM
dare2step's Avatar
Car: 92 camaro rs
Engine: 5.0
Transmission: 700r4 i know sad aint it
Axle/Gears: with this one i havent dug that dee
i replaced cap and rotor button plus coil but my car will still just turn over and wont fire its a 92 rs with a 305 v8 auto
any info would be wonderful
this car just shut down while driving to the store and hasnt started since
Old May 5, 2009 | 09:24 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Re: i cant get my motor to fire
are you seeing the injectors fire? If it is in fact spark related, i bet its the pickup in the dizzy, chevy has a nasty problem with these guys cracking internally, Try moving around the wire that goes to your igniton module(which could also be your problem) and see if it will fire for a second. If it does the wires in the pickup are cracked internally and make contact when put in a certain position.
Old May 6, 2009 | 09:29 PM
dare2step's Avatar
Car: 92 camaro rs
Engine: 5.0
the injectors are working properly ill check out this rest thanks
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Randomtask2
Aug 26, 2015 03:34 PM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
