Spark Advance?? Please help!
Old May 22, 2009 | 06:00 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
I have a 1983 Camaro 305 TBI crossfire injection. It will not rev past 2500 rpms. I replaced the cap and rotor and noticed the metal piece under the rotor will not turn for the spark advance. How do i fix it? please help. I sprayed it with wd40 still aint working
Old May 22, 2009 | 06:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Spark Advance?? Please help!
The metal piece under the rotor shouldn't move. So that is good.
The spark advance is controlled by the ECM.
RBob.
Old May 22, 2009 | 08:26 PM
Yea, but it should open up a little , because when that spins around it has to open to spark faster for the higher speed/rpm right?
Old May 26, 2009 | 08:32 AM
jfwireless's Avatar
You do not have mechanical advance in your distributor, the ECM does this electronically, so those metal wings under the cap do not move.
What does your timing light tell you ?
Jim
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Jorlain
Oct 8, 2015 01:57 AM
Jlanz55
Sep 9, 2015 09:09 AM
