Performance Suggestions please
Old Jun 2, 2009 | 07:51 PM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I want to get more torque out of my 1989 Camaro RS (305 V8).
I have money to spend and i cant think of what to do to make my car faster off the line.
Exhaust?
Headers?
Intake?
post w/e you got
Old Jun 2, 2009 | 10:00 PM
Klewis89RS's Avatar
Car: 86 IROC, 90 F-250
Engine: LB9, 460
Transmission: 700R4, C6
Re: Performance Suggestions please
I would start with headers and exhaust. I have hooker headers and exhaust on my RS and it helped a bunch
Old Jun 3, 2009 | 09:51 AM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
The first thing I did to my car was gut the cat (back in 1989). It actually made a small, but just noticeable difference. Next I added an open element 46mm TBI with bigger injectors (to handle future upgrades). Somewhat surprisingly, that really seemed to open up the top end a bit - revs picked up much faster and there was more "room" up there. These things didn't make much difference to the low end though - it was still the same down low. After that came an avalanche of modifications that are still on-going.
Perhaps the biggest immediately noticeable thing you could do is swap rear-end gears. I went from stock open diff 2.73's to posi 3.42 gears on a slightly modified 305 TBI and the difference to seat-of-your-pants feel was undeniable. Not all performance mods lie in the engine. The cars with numerically low rear diff gears (i.e. 2.73:1) NEED numerically higher gears (i.e. 3.42:1 in automatics and 3.73:1 in manuals) to wake them up nicely. The TransGo shift kit for the 700R4 is a nice, fairly cheap, addition too - assuming we're talking about an automatic, it'll put some life in your shifts.
My order of priority bolt-ons would be...
1) rear gear change (posi, then shift kit, if applicable)
2) cat-back exhaust
3) headers
4) intake (open-element, ported TBI, then manifold)
5) camshaft
6) heads (to get the potential of the cam)
...by step 5 you'll be getting into the need for prom tuning.
I've done a ton of things to the L03. I can fill you in to what I've done if you like, but the above bolt-ons are about where you want to go without getting into the internals.
Old Jun 10, 2009 | 02:49 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
1-5 is the way to go. I would wait to do heads and cam all at once. Keep the cat if you have to get emission tests. Not sure if it is still true, but get a headers and exhaust for a TPI car. Before I think you could not get a 3" exhaust for a TBI. Hooker 2055s or similar with y-pipe, performance 3" cat and 3" cat back will make huge difference.
Try to get gears out of a fourth gen 350; auto came with 3.23s and t-56s came with 3.42s. I got the whole drivetrain from 2 4th gens, t-56 from a 93-96 and the rear with 12" brakes from a 97-2002. Rims stick 1" out more than stock, but ok if you plan on upgrading rims later cause you won't need spaces to run 4th gen style wheels.
Veaceonee
Sep 29, 2016 08:15 PM
R13_Braz
Sep 18, 2015 05:00 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
scottmoyer
Sep 7, 2015 07:06 PM
