combination question
Old Jun 3, 2009 | 11:39 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
the old L03 is feeling a little worn,
I have a 350 in the garage, it has world sportsman II heads, 9.0:1 compression, and a comp cams 08-306-8 cam
cam specs as follows:
duration @ .050" Intake 230 exhaust 244
lift .510 intake, .540 exhaust w/ 1.5 rocker.
112 lobe separation
I would like to keep the car TBI, is that do-able?
Old Jun 6, 2009 | 01:10 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: combination question
it's do able. but you'd have to get into chip tuning.
Old Jun 8, 2009 | 12:19 AM
ericjon262's Avatar
thanks.
what kind of power and torque should I be expecting at the crank? any Ideas?
Old Jun 8, 2009 | 10:21 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I'm not a TBI expert, but that seems like a huge cam for TBI. Maybe it's do-able though.
Old Jun 8, 2009 | 10:46 PM
ericjon262's Avatar
I like big cams
Old Jun 9, 2009 | 12:55 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Originally Posted by ericjon262
I like big cams
Stock TBI ECM will not support that much overlap. Based on description this cam is better suited with a TPI and 2500 RPM stall converter (and modified ECM). I am venturing a guess that it will have low idle vacuum which will make MAP sensor very unhappy.
Also, with this much overalp and only 9.0:1 SCR that engine will feel lazy even with a carburetor.
//RF
Old Jun 9, 2009 | 09:45 AM
ericjon262's Avatar
how much higher should I bump my compression up? I was planning on converting to Mass air flow, do you see any issues with that cam and MAF?
Old Jun 9, 2009 | 03:15 PM
Ronny's Avatar
Question is do you want to spend the time to make it work? And do you value keeping EFI? As stated requires tuning, larger injectors, larger TB unit, a swap of fuel pump. knock sensor, ign module(?), and probable addition of a WB02 sensor.
RF: Why could he not run open loop and lose the NB02 running fueling off VE tables and WB02 feedback to ECU?
See what I mean, to want to make it work. MAF I believe is said to be easier to tune. Yet many MAF users convert to SD with MAP sensor.
Old Jun 9, 2009 | 03:25 PM
ericjon262's Avatar
I do value keeping it EFI, not really sure why, but I just don't want to go carb. if the car had a carb from the factory, I wouldn't mind, but since it came injected, I'd like to keep it that way. as far as tuning goes, it's something I'd like to learn to do, so I think it's worth the hassle.
Old Jun 9, 2009 | 05:45 PM
RFmaster's Avatar
Car: 75 Beast
Ronny
Sure - I would disable CL at idle first and get my VE and spark tables dialed in to give this engine combo what it wants. Once this engine can maintain idle I would start looking at WBO and NBO correlation at various idle speeds looking for false exhaust lean areas. Based on experience dialing in idle is about 50% of conversion headaches! Nothing more embarrassing then a car that will not hold idle and stalls at stop lights! To do so requires ECM reprogramming and appropriate skill set.
Every time some of my friends come by and ask me for an opinion, after going to the bottom of the cam companies catalog page, as to which cam they should install in their high priced rides I always ask them what are their goals and expectations. Most of the time it either DD or WR! Hence, cam that is more docile (mid page) is usually appropriate choice. Note that you have to consider the whole package (car, engine, drive train, the driver).
Switching to MAF introduces another set of problems. There are threads that cover MAF vs. MAP pluses and minuses. I am not going to venture into that abyss!
//RF
Old Jun 9, 2009 | 08:47 PM
ericjon262's Avatar
it's a DD right now, but when I finally blow up the L03, that will be another story!
Old Jun 10, 2009 | 02:36 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Is the 350 a roller or non-roller. Not to say that non-rollers are not tunable, just not as forgiving as rollers.
Just to make sure you know, you need closed loop only if you are running a catalytic converter. Luckily for me, I converted to stick and do not have much problems with idle. I had it idle at close to 15Hg but messed with some stuff not it flutters around 10.
I see you have an 83 as well. I just went through a whole 350 upgrade to my dd while my 83 still remains not running. Take my advice and either get rid of the 83 or just keep the L03 running and get your racecar complete. Like me, too many projects, not enough time or money.
Old Jun 10, 2009 | 02:43 PM
Ronny's Avatar
I am non emishions with no cat-con. I ran OL for a season and gas mileage was terrible. Here in WI it can be 45 ded in morn and 75-80 in late afternoon. Running CL accounts for those swings in temps.
Old Jun 10, 2009 | 02:48 PM
ericjon262's Avatar
It's a roller 350, I'm considering selling my '83, I'm not sure yet though, I do know, that I want to finish my paint and my inteior on my '91 before I build a motor, I'm sick of driving ugly cars! I don't have emissions check here in Florida, so thats not an issue.
RFmaster:
you mentioned I should bump up my compression, how high do you think I should go?
Old Jun 11, 2009 | 12:25 AM
RFmaster's Avatar
Car: 75 Beast
RFmaster:
Eric
With your roller cam that has a decent overlap of 74.50 degrees, advertised duration 290/307, I would consider going to 9.5 to almost 10.0:1 on premium pump gas since you have modern heads to boot (they flow). With hydraulic roller tappet both intake and exhaust valves are lifted during overlap (same as with flat tapet). With fast ramp rates afforded by roller based cams valves are lifted faster and provide more cross flow during overlap effectively reducing dynamic compression. Check this handy calculator here:
http://www.wallaceracing.com/dynamic-cr.php
An extensive explanation can be found here:
http://members.uia.net/pkelley2/DynamicCR.html
Every 1 point increase in static compression ratio (SCR) will increase your torque 3-4%. Again - you always have to ask what is your goal and budget!
/?RF
Old Jun 11, 2009 | 09:42 AM
ericjon262's Avatar
well, thanks for all of the help, looks like a piston swap should be in order than.
what do I need so I can start data logging?
I know it won't help much for the 350 til it's in and running, but I'd like to learn to tune on my 305 so I have a foot in the door when I go to put the 350 in.
Hawk312
Aug 22, 2017 08:55 PM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
