L05 ECM retarding timing
Old Jul 9, 2009 | 10:25 AM
WagonmasterRuss's Avatar
Car: 1993 Caprice Classic "Woodie"
Engine: 350 TBI W/EBL Flash
Transmission: 4L60 S10 converter
Axle/Gears: 8.5, Torsen T2, 3.73s
Hi guys,
Stock internals, headers and exhaust 1993 L05 in my Caprice.
The car has been running like Cr@p, did all the tune up stuff, no Joy.
checked timing, it was correct at 0 W/spark control unplugged.
Then I reconnected, reved the motor and noticed that the spark was being retarded almost to the point that I couldn't see the mark! (timing mark moves almost back to the powers teering pump)
Prior to running poorly, I had to run high octane to keep from pinging.
What gives, Knock sensor?
Old Jul 10, 2009 | 10:48 PM
Re: L05 ECM retarding timing
Old Jul 11, 2009 | 09:37 PM
HMMM,
used WINALDL to check it out and it shows 0 knock count from the knock sensors? Seems like it should be showing SOME knock.
Maybe it is a dead knock sensor, but why would if pull timing if it detects no knock?
I heard WINALDL may not fully support my '93 computer
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
