Cam duration?
Old Jul 11, 2009 | 11:58 AM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Engine: 305 TBI, still deciding
Transmission: 700R-4, still deciding
Axle/Gears: stock, 3:73 IROC
Cam duration?
Ok, I have been looking through everything I can find about cam choice for a 305 with TBI. From what I have read I need to keep the cam LSA between 11-115. My question is...is there a maximum duration I should not go above? I will be getting a set of aftermarket heads to go along with the new cam. Compression will be 9.5-1 to 10-1. Any suggestions or tips? Thanks for your help.
Dave
Old Jul 13, 2009 | 03:04 PM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Re: Cam duration?
Anyone?
Old Jul 13, 2009 | 03:29 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam duration?
I had a nice TBI 305 combo once, that I really loved. It was just over 10:1, with milled heads and flat-top pistons. Also, I had cut some #416 heads for 1.94" intake valves (I'm an automotive machinist, so I did the cutting) and ported and polished them. I used a COMP CAMS 12-388-4, I believe it was. It was hydraulic flat, not hyd. roller, with advertised duration of 252/260, duration at .050" of 206/212, lobe separation of 112, lift of .425/.440. This might not work at sea level, I was a couple thousand feet up, in Chattanooga, TN. You can go bigger with the cam, but I'm not the one to ask about that. I was using a 700R-4 and a 3.42:1 axle, and a B&M TorkMaster2400 converter, Edelbrock's intake, and crappy Hedman headers. Still, I had traction problems, but I wasn't using drag radials.
Old Jul 13, 2009 | 06:19 PM
DJ_91RS's Avatar
Car: 91 RS, 89 IROC
Re: Cam duration?
Thank you Atilla, I have read a lot of your posts and value what you have to say. I am going to go with a vortech head (which one I don't know yet), 10:1 compression as well, roller cam since it is an LO3, various suspension goodies also, and beef up the 10 bolt in it for now. I figure it should live ok behind what I will get out of the 305. 700R trans as well will get some attention to. I am going to keep it TBI and learn how to tune. Figure I can use it to help some of the Third genners around here! I will try posting this in another section to see if I get more hits. Thanks again.
Dave
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
