Hesitation in a 83 Crossfire 305 TBI
Old Jul 16, 2009 | 07:57 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
I think my car is running rich, If I floor it from a standing stop it Its very hesitant and when i suddenly let off the gas it just barely stays running. What could the problem be and how do I fix it? Also when i floor it and it wants to stall I smell alot of gas
Old Jul 19, 2009 | 03:57 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Hesitation in a 83 Crossfire 305 TBI
The throttle shafts are notorious for wear on the CFI units causing the problems you are describing. Also has ayone tried to adjust the linkage between the TBI's? But to back up a little have you done the basics of new fuel filter , plugs , cap/rotor/wires? I know this may be a simple answer but it's over looked a lot. I will have to look on my other computor for some helpful links on the CFI system - they have been with mine.
Old Aug 6, 2009 | 08:22 PM
dford's Avatar
Are there throttle shaft bushing kits available? A rebuild kit?
Thanks.
Dan
Old Aug 8, 2009 | 12:42 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Dan
Take a look at this link
http://www.thecubestudio.com/Crossfi...estoration.htm
There also are a few companies out there that rebush the shafts and/or rebuild the TBI.
Some of the folks that rebush the shafts can be found at http://www.crossfire.homeip.net/
I think one of the other companies is DCS, but I don't have a link for them.
Old Aug 8, 2009 | 01:09 AM
Is the check engine light on when you have these problems? If not, are you sure the bulb is good?
One other thing you can visually check is all the vacuum lines for cracking or leaks. The TBI system does not like vacuum leaks.
Since you smell gas when you floor it, you might want to try the following to see if you observe anything wrong with either throttle body.
Get the engine warmed up to normal operating temperature and turn it off. Make sure the parking brake is engaged and that you block the rear wheels, on the front side. Now take off the air cleaner cover, the air filters and the bottom of the air filter. This will give you a good view of both throttle bodies.
Now start the engine up and go back to in front. The throttle linkage is at the back side of the rear TBI, in between both of them. Using the linkage, rev the engine up and observe the operation of the throttle plates and the spray pattern of the fuel injectors. I am wondering if one of the throttle plates is not opening when you mash it. Be careful here, becuse if you get fuel on the hot block, it might ignite. That would not be good for you or the car. It might also be a good idea to have a good fire extingsher on hand ready to use.
You might also want to take a look at the link I posted in response to Dan's question. There is a lot of good information there, but it takes a while to read through and understand it all.
Old Aug 8, 2009 | 09:08 AM
dford's Avatar
Great link. Thanks Dave.
Is there another way, other than the manometer, to check for shaft bushing wear? Carb spray around the shaft?
Thanks.
Dan
Old Sep 14, 2009 | 06:26 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Sep 14, 2009 | 08:31 PM
dford's Avatar
Yes,
Sorry guys summer is crazy busy.... But I found the hesitation at least. It was gunk on th enew plug I installed. Those plugs are double tuff to change. Well I aparently scraped some gunk off putting the new one in. Cleaned it and it runs AWESOME. Yes it needs a few minor things cuz heck it's not new but it made all the difference in the world.
Now if I can figure out the stalling thing. Might still be in the tank but I will update once I get back to it.
Dan
Old Jul 21, 2011 | 06:39 AM
KITT1983's Avatar
Any updates?
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
