lt1 cam question
Old Jul 17, 2009 | 01:04 PM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
lt1 cam question
First off, I searched and nothing came up answering my question.
Who has done the cam swap and dynoed there car? what kind of performance did and what numbers are you pitting down now? Anything else you do to aid the cam swap?
Old Jul 17, 2009 | 01:42 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: lt1 cam question
In my sigh you can find my mods. Not dynoed yet, but has no problem keeping up with stock LT1 4th gens.
Old Jul 17, 2009 | 02:15 PM
Chezoom's Avatar
Engine: LO3, LG4
interesting intake, whered you get it an how much?, you have some good moods to look at, anyone else?
Old Jul 17, 2009 | 04:05 PM
Chezoom's Avatar
Engine: LO3, LG4
NEW Question, what about an LS1 Cam?
Old Jul 17, 2009 | 04:08 PM
Spiers's Avatar
Are you serious? What do you call "keeping up with?"
Old Jul 17, 2009 | 04:24 PM
Spiers's Avatar
To the OP...
You will have to grind the dowel pin on the LT1 cam down a bit but that takes like 2 seconds. An LT1 cam with new springs and what not plus a tuned chip and exhaust can supposedly be worth 25-40hp.
Old Jul 17, 2009 | 06:05 PM
thomas1976's Avatar
Car: 91 Trans am
Serious, kickdown LT1 gets like 10 feet slight better accelleration wich my trans am catches up. Althoug driving the 4th gen does feel faster (specially wenn you push the "power trans" button), must be the stiffer body and stiffer seats.
Although if I calculate what I spent untill now, I could easely buy a used LS1 4th gen. They are a little faster then mine.
Old Jul 18, 2009 | 01:32 AM
Spiers's Avatar
So your TBI will run a low 14 in the 1/4 with bolt ons and an LT1 cam? Not calling bs but I really would like to see some proof, maybe a time slip or video?
And by the way, I have 2 good stock '96 LT1 cams sitting in my garage
Old Jul 18, 2009 | 02:01 AM
Chezoom's Avatar
Engine: LO3, LG4
mind giving an 18 yr old that has hopes of a semi kind of almost quick car a good deal so i dont get passed by hyundia's?
Old Jul 18, 2009 | 12:09 PM
Spiers's Avatar
How does $40 shipped sound
Old Jul 18, 2009 | 12:52 PM
Chezoom's Avatar
Engine: LO3, LG4
ehh, ive found one at $25 shipped, seen one at $20 shipped but i was second on that one.if you have a better offer then lmk, if not tho
Old Jul 18, 2009 | 01:51 PM
thomas1976's Avatar
Car: 91 Trans am
Im running the following cam. 208 230, .450 .460 ,116, GM 94-95 LT1
No 1/4 tracks here, to be honest havent had the chance to test from a stop, but im preatty confident ill catch up. Waiting to bring it on a test bench. Good you dont claim bullshit, it does actually still snap quite hard wenn shifting in to 3rd. The set up is actually sucking up fuel for little over 280hp at the moment. The car has 78k miles now and is like new.
The engine bay was not cleaned in the pic.
https://www.thirdgen.org/forums/atta...d-dsc04997.jpg
Old Jul 18, 2009 | 04:31 PM
Spiers's Avatar
Where did you get those specs? Do you have any videos of the car?
Factory LT1 camshaft specs:
1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
93-95 Y,F-body: 202/207 0.450/0.460 lift 116 LSA
94-96 B-body: 191/196 0.418/0.430 lift 111 LSA
96 Y-body, 96-97 F-body: 200/207 0.447/0.459 lift 117 LSA
96 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
Chezoom, sorry I don't have a better offer. Shipping would be approx. $15 and the cam is worth ~$25. So I thought $40 would be a fair price.
Old Jul 18, 2009 | 05:03 PM
thomas1976's Avatar
Car: 91 Trans am
Sorry no videos. The spesc are from this chart, may not be perfect. I have mesured the lift and knowing the year of the camaro it came from it matched, but your numbers dont look too different.
http://www.malcams.com/legacy/misc/CamData.htm
Old Jul 18, 2009 | 08:12 PM
Chezoom's Avatar
Engine: LO3, LG4
newb question for sure i know...but, do you have to rebuild the whole engine to do a cam swap or can you just replace it, i know other things have to be replaced such as valve train parts, timing chain ect ect, but my engine just rolled 101,000 miles today infact and my grandma is the orginal owner, she drove in very easy and put 91,XXX on it, i put the rest.
Old Jul 18, 2009 | 08:31 PM
Spiers's Avatar
Lol no you do not have to do a rebuild. All you need is the cam, and I would also get some LT4 valve springs and a new timing set. Don't forget your fluids and gaskets that you will need. All of this could cost you less than $100.
Old Jul 18, 2009 | 10:16 PM
Chezoom's Avatar
Engine: LO3, LG4
from my research, ill need more than just the cam
Parts needed:
LT1 camshaft….Free-$50
Timing chain set – Part number 12371043 (from Scoggin Dickey)….$50
Valve springs – Part number 249-981-16 (from Jegs)….$60
Intake manifold gasket set – Fel-Pro MS93317….$15
Timing cover gasket set – Fel-Pro TCS45121….$8
Water outlet (thermostat) gasket- Fel-Pro 35062….$2
TBI unit gasket – Fel-Pro 60903….$7
RTV silicone sealant (gasket maker) and thread locker….$10
Fluids – Oil, coolant….$20
Old Jul 18, 2009 | 11:52 PM
Spiers's Avatar
Well that's what I just posted...
Old Jul 19, 2009 | 12:38 AM
Chezoom's Avatar
Engine: LO3, LG4
my bad, i miss read it as you "could"
Old Jul 19, 2009 | 05:29 AM
thomas1976's Avatar
Car: 91 Trans am
Master ShiftyCapone's LT1 digest, you already discovered, will give you all information. I used all the suggested parts (upgrading valve springs is a must).
Only thing not mentioned is removing the air condition radiator and filling it up after reassembly, good time to upgrade to R134a refrigerant.
https://www.thirdgen.org/forums/tbi/...-ultimate.html
I would also add EBL flash to the expenses, or burn some 500 chips. Keep in mind EBL has some wery useful features you really need to make power that the stock ECM dosent have.
Old Jul 19, 2009 | 06:38 AM
Chezoom's Avatar
Engine: LO3, LG4
do i ave to retune the ecu if i change the cam or is that a good supporting mod?
Old Jul 19, 2009 | 09:58 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
If you want the most from your cam swap you need to update the tune. I wouldn't go to all the work of swapping a cam and then leaving the tune stock.
Also, if you have not added headers, y-pipe, 3" cat and exhaust, a cam swap won't help much. Get the full exhaust taken care of first.
Old Jul 19, 2009 | 12:17 PM
Chezoom's Avatar
Engine: LO3, LG4
looks like im gonna have a nice little parts pile for a while, shorty headers or long tubes, i want the most power, what if i hollowed out a cat, since i have an extra laying around ive heard about doing that, also what help would an RPM prefomer intake do for me?
Old Jul 19, 2009 | 03:33 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
R134a IS NOT AN UPGRADE BY ANY MEANS..... Its a DOWNGRADE, BIG TIME!!
Old Jul 19, 2009 | 03:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I put out over 240 RWHP with a .030" over 2001 305 L30 vortec block, flattop pistons, 187 swirl ports, LT1 cam, Edelbrock 3704, Doug Thorley Tri-Ys, and DIY programming on the 1992 TBI Van "299" ecm I was running. Was able to get a 1983 G20 van complete with 29" tall tires, 3.08 gears, and stock 1,600 rpm torque converter well into the 15s in the 1/4 mile.
Old Jul 19, 2009 | 03:55 PM
thomas1976's Avatar
Car: 91 Trans am
Since your in texas, you must know, having extreme themperatures. My a/c works perfectly with r134 like the billions of more recent cars, but true we rarely have over 45°C here.
Wenn it comes to recycling and getting wasted in to the atmosfere the r134 is a upgrade.
R12 is legal to produce in wery small quantitys and if you find some, its origin is mostly from black markets in china and smuggled worldwide, so up to you to decide who's living you whant to support.
Old Jul 19, 2009 | 04:08 PM
Chezoom's Avatar
Engine: LO3, LG4
which is cheaper, ill assume the r134, i need a,c we have been over 100 everyday for a while now...
Old Jul 19, 2009 | 04:20 PM
thomas1976's Avatar
Car: 91 Trans am
45°C = 113°F And even with these themperatures my r134 filled a/c is not overwhelmed, true it is a coupe not a van.
black market r12 is cheaper
Old Jul 19, 2009 | 06:05 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
what do u have to do to switch to r134 cause i need ac too.. its not been to hot here but it would be nice to have since im moving out to southern cali
Old Jul 19, 2009 | 06:20 PM
Chezoom's Avatar
Engine: LO3, LG4
quickkris, how did you go about porting your intake?was it worth anything? pics?
Old Jul 19, 2009 | 07:13 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
R12 is CHEAPER....I have my certification and can buy it for like $20-30 a 12oz can from NAPA or Orielly's.
Old Jul 19, 2009 | 07:49 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
long tubes are a pain, shortys and a y-pipe will be fine. You need a y-pipe that is nicely merged, the factory T-pipe is unnaceptable. Dont gut a cat, for one the stock one is too small, second its illegal. Buy a high flow 3" cat when you do the headers and cat back. Check out the exhaust board for details.
Old Jul 20, 2009 | 03:48 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
+1 on exhaust upgrade. easiest mods to do and will give you nice gains on these engines and their lumpy stock exhaust systems. i'd recommend hooker 2055 headers, catco 9118 3" high-flow cat and hooker 16823 3" aerochamber cat back system. great setup for flow, sound.. maybe not for the wallet though in any case, just a necessary requirement for future mods. and although you can gain even more with a chip tune, i would say it's not absolutely necessary to tune the chip for exhaust improvement, whereas a cam change imho does necessitate tuning (and proper fueling).
Old Sep 20, 2009 | 12:04 AM
jb112303's Avatar
Car: 1990 firebird
Engine: 305 tbi (L03)
Transmission: auto
Axle/Gears: stock
that isn't cheap, u can get an 8oz can of 134 for like 6 bucks
Old Sep 20, 2009 | 12:26 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Compared to dissasembling your Stock R12 system, flushing out the mineral oil, updating the condensor, and installing barrier hoses it is CHEAP. For the difference in a/c cooling capacity, it is nice staying with R12.
If you like even better cooling there is a cheaper, much more efficient, environmentally friendly alternative.
Old Sep 20, 2009 | 12:34 AM
jb112303's Avatar
Car: 1990 firebird
Transmission: auto
Axle/Gears: stock
lol i was just referring to the price of the cans, do 90's firebirds have r12 or 134?
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
