zz4 cam and fuel pressure
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Just out of curiosity, those who run a zz4 cam or have in the past with a tbi system what fuel pressure did you set the regulator at? I know right now i am at about 14.5 psi with 350 injectors but i have the lean back fire at wide open throttle and at 17 the car smelled a little rich at idle and low speeds. I dont want to set it too high and have it run even richer but i dont want it to run poorly either, i am looking for that happy medium.
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
Re: zz4 cam and fuel pressure
Engine: Built ls1
Axle/Gears: 3:42
it is a 305 with 113 heads, 1.6 rocker arms and tbi with ultimate tbi mods. I have the tpi fuel pump as well, with the 350 injectors. The computer has been tuned with a few chips burned in the process. Dont get me wrong the car runs strong, but i am curious as to where other people set their fuel pressure with larger cams without having the rich at idle problem and lean up top.
Car: 92 camaro rs
Engine: lo3 305 tbi
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Unfortunately the stock ECM dosent allow such a FPR to be tuned in, fortunately EBL does and its easy to set up and tune with.
Here is the EBL flash.
http://dynamicefi.com/
Here the VAFPR that mounts at the stock location that I use (if your skilled you may mod your stock one). It requires to use shims to obtain the desired FP, thakes like 2-3 trys (15 minutes) to get it right there. Then you need some vacuum lines and connectors.
http://www.turbocity.com/product_inf...roducts_id=602
Tgo member dctrumpet has all the necessary gaskets and more.
Car: 91 Trans am
Quick check with EBL 's calculator, 20psi for 286hp and 28psi for 338hp, thats around what your set up will require with 61 lbs injectors.
Engine: Built ls1
Axle/Gears: 3:42
Thank you for the feedback and the information. You currently use the ebl system with your setup correct, is it as easy as everyone says to tune with. I will set the system back up to around 20 psi for now until i can afford to get the ebl setup and the vafpr.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I run the EBL as well, with a stock regulator (with stiffer spring) at 21psi with stock 55lb injectors. I run commanded 12.5 or so AFR up to about 6k RPM. So it's enough fuel for my setup. Idle is perfect without a vacuum reference.
Engine: Built ls1
Axle/Gears: 3:42
How hard is it to tune with the ebl, I am pretty new to tuning.
Car: 92 camaro rs
Engine: lo3 305 tbi
I can get the zz4 cam for free so I was just wondering if it's worth it and I just got some vortec heads as well so I might be hollering at you about the tuning as well.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Did you say your running 1.6's with ZZ4 cam? you had better change the springs on the exhaust side. With 1.6 rockers it takes the exhaust lift to .544. The stock ZZ4/LT4 springs are only good to .525. I would highly recommend putting the 1.5's back on the exhaust. As far as tuning with the EBL it freaking awesome. Even a noob like myself can get a good handle on it after a few runs.
Engine: Built ls1
Axle/Gears: 3:42
I changed the springs to a 600 lift rated spring when i did the cam so that is not an issue with the 1.6 rocker arms.
Engine: Built ls1
Axle/Gears: 3:42
I cant get intouch with the people at dynamic efi, the email for bob is returning an error. Anyone have any info on how to reach them or another place that sells the system?
Car: check
Engine: check
Transmission: check
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
