Please help with blow by issue
Old Aug 23, 2009 | 08:53 PM
transtang78's Avatar
Car: 90 Camaro RS
Engine: 350 roller bored 30 over
i have a 90 rs with 5.7 from a 94 van tbi now the problem when i start the car the egr valve pulses up and down and the car runs likecrap if it even stays running, so i disconnected the egr solenoid and the car rus great but it builds crankcase pressure. egr seems to hold pressure with a vacumm pump, i replace ecm the other day but i think the problem is the egr solenoid after i replaced it and started the car it took time to idle but when it did i had a lot of crankcase presure enough to push oil out the dipstick tube. anyone have any ideas
Old Aug 23, 2009 | 10:14 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Please help with blow by issue
Welcome to the board neighbor.
I doubt a blowby problem is causing the EGR problem.. However it could be a bad or incorrect EGR valve or even a plugged catalytic converter. A catalytic converter that is stopping up would make the most sense as it would cause excessive blowby past the rings as well.
On a side note what other components were used for the swap? Does it have the 350 injectors, 350 knock sensor, and 350 ECM?
Old Aug 23, 2009 | 10:23 PM
Car: 90 Camaro RS
thank you neighbor, the cat is new only 2 mths old, if the egr valve isnt opening properly wouldnt that cause excess gases to build up. i dont understand why the egr valve surges up and down.
Old Aug 23, 2009 | 10:26 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I honestly haven't messed with the stock EGR valves from the F-bodies much, but I know on the Trucks/Vans the valve is designed to pulsate as it regulates the flow of EGR into the intake. GM made about 3 different types of EGR valves depending on the application and I know a 1994 Van uses a different control method than the F-car did. What this amounts to is you need to run the OEM 305 F-car EGR valve if you are using the stock ECM.
Old Aug 23, 2009 | 10:40 PM
Car: 90 Camaro RS
i will try that
TheTraut88
Sep 11, 2015 05:16 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
90formulaVortec
Sep 3, 2015 09:26 AM
