Vortec TBI stock tune ?
Re: Vortec TBI stock tune ?
I'm trying to put TBI intake on
here's what i got
stock Vortec 305
stock Vortec 305 heads
stock vortec cam
carb intake
adapter to mount my TBI
PCM 16197427--------------------------------for 1995 TBI 4l60e
stock 305 prom------------------------------for 1995 TBI
40 LB 305 injectors-------------------------for 1995 TBI
Stock TBI fuel pump 10psi-------------------from 1988 TBI
Do you think it would run with the stock prom chip ? What should i expect ?
I was thinking of getting a mail order chip , it may not work perfect but it probally would work better then the stock chip
here's what i got
stock Vortec 305
stock vortec cam
carb intake
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
WOT you will probably be out of fuel by 2000rpm using 40lbs injectors with only 10psi FP.
A stock TPI fuel pump will allow you to bump the FP up to support way more hp, dataloging and tuning will be a must.
Yea your right , i've been researching and it seems i need 65 lb cop car injectors with stock fuel psi or 55 lb injectors with 18 psi of fuel psi
Big problem is the tune , since i dont know how to burn chips i'll have to forget about this idea!
Car: 1983 G20 Chevy
Transmission: 4L60
The only thing is he has 55# injectors currently in the stock 305 as thats what ALL 305s had.
Hey 355 , check out my van
http://www.fullsizechevy.com/forums/...ortec-tbi.html
Car: 91 Trans am
You can find great support to dial in your set up here on tgo.
So is this chart incorrect ? this is where i got the idea that 305 injectors are 40lb and 350 injectors are 55lb
so are 305 injectors 55lb and 350 injectors 61lb ?
Car: check
Engine: check
Transmission: check
The chart is wrong. Early 5.7l injectors are 61#/hr and the 5.0l injectors are 55#/hr. This is at 13 psi of fuel pressure.
Later 5.7l injectors are 65#/hr and 68#/hr.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
My biggest issue with that chart (and other early information) is how it ends up on so many other sites and they treat it as gospel.
RBob.
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
