timing belt setup?
Old Sep 14, 2009 | 08:26 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
timing belt setup?
i did some research and looked into the whole underdrive and shorter belt but what i came across was the idea of a timing belt.... has anyone attempted with a 305 tbi to go with a timing pully & belt and maybe underdrive pullies to follow up that are timing?
i was thinking to do (crank,water,alt,& maybe ps)... just want some opinions and ideas...
Old Sep 15, 2009 | 12:48 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: timing belt setup?
so you dont mean install a timing belt where your current timing chain is? you mean replace a serpentine belt with a timing belt? thier is no need for that. a timing belt is designed to handle immense pressure from turning over an engine while a serpentine is designed to run smoothly while being driven by the engine.
Old Sep 15, 2009 | 07:33 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
oooh, i never knew that. hmm.. would there be an easy way for a 305 tbi belt setup to be made with taking out the smog pump and ac?
Old Sep 15, 2009 | 08:10 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Smog & AC Delete Pulleys...
Raf
Old Sep 15, 2009 | 10:06 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
All you really need is the A/C delete pulley - the smog can be removed by simply rerouting a longer belt ...
https://www.thirdgen.org/serpentine
Old Sep 15, 2009 | 07:55 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
would there be any true gains? considering just removing the smog and keeping the ac pulley... thats only a couple inches it seems :\
Old Sep 15, 2009 | 10:05 PM
Car: 1992 RS
Engine: Carbed 350
For most guys, a few inches is a huge gain!
I'm not sure there's any hp gain in removing any of it - the A/C doesn't make much resistance since it's free spinning unless the A/C is on and the clutch on the compressor engaged.
HP isn't gained or lost by length of the belt (just ask my wife). It's the tension that the accessories create, which is very little.
Old Sep 15, 2009 | 10:58 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
better response? and less work for the crank to have to drag? i heard it helps gas mileage and a bit of power... dont know the amount but...
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
