need help fast. double hump heads
Old Sep 15, 2009 | 11:59 AM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
will sbc double hump heads bolt directly up to my tbi? and if so would i have to burn a new prom for them and a cam?
Old Sep 15, 2009 | 12:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: need help fast. double hump heads
Yes they would bolt right up to the block, but you would need a different intake manifold as the bolt pattern changed in 86. As with any modification to the LO3 you will want to burn a new chip to make the best out it. This is especially true with heads and cam. It is a 100% must or else the car will be a sputtering, gas eating, undrivable mess.
Old Sep 15, 2009 | 01:47 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Do they have the same accessory holes?
Old Sep 15, 2009 | 02:10 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Double-hump "fuelie" heads will not have accessory bolt holes. A set of Vortecs would be much better.
Old Sep 15, 2009 | 02:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I can't recal off hand (memory failure) but a quick side by should should tell you. Can I ask why you want to use these heads? You might get better value by selling them and using that money towards a set of reworked and ported TBI and or TPI heads which will yield similar performance. DH heads are highly sout after and can fetch a pretty penny. They are decent performers but nothing special. Especially since you would have to change intakes, and possible front accessories.
Old Sep 15, 2009 | 02:45 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
well im getting them at an unbeatable price. very very very low 3 figure price. but i gues il pass.
Old Sep 16, 2009 | 07:05 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would buy them and re-sell them. You will find someone willing to pay top $ for them. Any value you get from the heads at a low cost will be swallowed up by the additional dollars needed to run these heads correctly. You will lose money in the end.
Old Sep 16, 2009 | 04:17 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
well id be buying them from a friend who was going to help me instal them. so i cant buy them for resale.
Old Sep 16, 2009 | 04:52 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Yeah, that would be uncool.
What CC are the chambers on Fuelie heads? Wouldn't they be too large for a 305 anyway?
If you don't mind tuning, you could pick up a edelbrock performer intake manifold and bolt up your TBI with some kind of an adapter plate.
EDIT: just read Fuelie's are 68 cc, that's on the large side for a 305. I'd kindly decline the offer.
Old Sep 23, 2009 | 03:31 PM
gheatly's Avatar
Car: 1982 Z-28
Fuelie heads are 64cc. They came in big valve (2.02/1.6) and small valve (1.94/1.5) varieties. I understand (but could be wrong) that big valve heads will not fit a 305 because the cylinder bore is too small.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
TreDeClaw
Aug 14, 2015 06:58 PM
