need help 4.3 TB Injectors drible and oze tones of fuel
Subscribe
Sep 28, 2009 | 12:03 AM
Hi I am new to this sit but I have tried searching everywhere, I had just purchased an 88 s15 with a 4.3L just cause I really like em and the price was right but I cant get it running. as soon as I crank the engine or prime the pump the injectors open and just poor fuel in they dont even spray flooding the engine. checked for spark and was good, i eventually disonected the fuel and cranked it for fear of over flooding, pulled the plugs and there all black, I tried to get it to flash a little with a little fuel down the TB and it barley stumbles, I checked the grounds and there all good and wires to the injectors, just dončt know where to start now can anyone help.
Reply 0
Sep 28, 2009 | 12:14 AM
Re: need help 4.3 TB Injectors drible and oze tones of fuel
could be bad o-rings where the injectors fit into the
throttle body,o-rings could also missing if someone has
tampered with the injectors and forgot the o-rings
Reply 0
Sep 28, 2009 | 01:56 AM
ok sounds like a good idea, is there a trick to getting them out
Reply 0
Sep 28, 2009 | 09:57 PM
ok so I have solved the rich problem(I think), I have no experience with the tbi stuff and unshure about the regulator but I found that the regulator spring was busted. I had switched injectors aswell but I think they must have been no good cause I had pressure right to the injectors, but nothingout from them, the previous owner had botched the firing order, but now the problem is it wont fire, I have spark, and fuel (from adding manually) but still wont flash if Im lucky it stumples for a second or two , I was wondering if crank speed might cause it not to flash up , I am trying to start it of my other truck with jumper cables, I fried a starter trying to get it running yesterday and the starter I put in is kinda slow aswell aswithched the tps and ais map aswell
Reply 0
Sep 29, 2009 | 12:02 AM
you will have to check for voltage at the injectors to see
if the ECM is trying to activate them,also injectors will
often stick if they sit unused for a while,there are
several methods to unstick them
Reply 0
Sep 29, 2009 | 01:35 PM
ya the injectors I swaped in where out of a truck that had been sitting for some time, I used the original regulator with the original injectors, replaced the regulator spring and they seem to be firing right, asides a little drip after they open. I thought that shouldnt be that bad, I just dont think Im cranking fast enouf to start now, I get two tree slow revolutions before compretion stops the starter dead.
Reply 0
Sep 29, 2009 | 03:31 PM
With the compression stopping the engine along with the previous firing order being off. It sounds like there is now too much spark advance. That will cause a hard crank condition.
Also need to be careful to not flood the engine.
Best bet is to work on getting the distributor timing closer to 0 BTDC. There are various methods to do this. If you have a timing light use that. Disconnect the injectors, loosen the distributor clamp, get some one to crank while holding the throttle open, and use the light to get 0 BTDC via the distributor position.
Then snug the distributor, re-connect the injectors, and see if it starts.
RBob.
Reply 0
Sep 29, 2009 | 06:28 PM
ya I took everything apart lined up the crank on the mark set the distributer at 0 tdc or as close as the eye could get, (I droped my timing light). whenever I thought it might be flooded I cranked it withought any plugs a few times and let it sit awile, whats the worst thing that could happen by flooding it Im sure it was flooded a coule of times, spark keeps looking strong....and Im picking up a new starter and batery tomorow.
Reply 0
Sep 29, 2009 | 08:29 PM
Holding the go-pedal to the floor while cranking is a clear flood mode. The injector PW is reduced to clear the engine of fuel.
RBob.
Reply 0
Sep 30, 2009 | 03:08 PM
OK so now Im banging my head of the fender, I really dont know what to say, I just installed a new starter and battery and its cranking way faster, but still will not fire got air got fuel and got spark double checked everything and just don't have a clue, the only thing I havn't cheacked is comprestion and I know I have some cause the old starter wouldn't pass through it. I even jacked up the rear of the truck to level the engine to make shure all cylenders are getting some fuel
what the heck am I missing
Reply 0
Sep 30, 2009 | 05:42 PM
ok so I finaly got this truck to run I got thinking of some of the two strokes I had worked on and when back out took the plugs out, hay wired the throtle open removed all the plugs cranked it again a dozen times let it sit awile tried firing it with out the injectors pluged in a couple of shots of starting fluid reconected the injectors, then she fired butn run like crap, she bogs and stalls when I crack the throtle so I guess its back to diagnosing. thanx for all the help a second opion alwas helps
Reply 0
Subscribe
