Vortec L05 LT1 LT4 Hotcam question
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Guys i have GMPP vortec L05 , stock rocker arms + 206/218 480.488 lift cam + Comp Cams 249-981-16 springs now. and want to instal http://www.summitracing.com/parts/CCA-07-503-8/ 224 int./230 exh. 503.510 lift cam do i need to machine heads or install 26915 CompCams springs ? for up my lift to 550 ? thanks
Car: 91 Camaro RS
Engine: 355 Vortec
Re: Vortec L05 LT1 LT4 Hotcam question
Yes, the beehive springs with the matching retainers will allow you to run that cam without any machining. Here is a link to an article about it.
http://www.carcraft.com/techarticles...ade/index.html
In my case I used Crane Valve Spring Retainer Kit – P/N 10309-1. Works fine, but the Crane kit is no longer available.
Car: Firebird 91
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Yes Also you need Comp Cam retainers PN 787-16, $50 from Summit, and valve stem seals you can pick up at a local parts store for under $2 each, either cross Sealed Power PN ST2015 or look them up for a Dodge Daytona 4cyl Turbo.
Also to same some money on shipping across the ocean you might try a GM dealer over there. GM PN: 12499224 set of 16, same EXACT thing summit sells.
Car: Firebird 91
Car: 87 Chevy Short Wide
Engine: 383 Vortec TBI
Like this http://www.summitracing.com/parts/NAL-12499224/ ?
Car: Firebird 91
at this time im runing edelbrock performer rpm , but in about few month I will install http://www.summitracing.com/parts/EDL-2913/ and one of those cams. ECM is 6965 from 9C1 caprice . im doing tuning myself
i upgrade ecm for AT29LV256 microchip , use WinALDL and tuner pro . i think im doing it well
so editing the program is not a problem.
so editing the program is not a problem. Junior Member
so editing the program is not a problem.Joined: Jan 2005
Car: 1983 G20 Chevy
Transmission: 4L60
so editing the program is not a problem.http://www.summitracing.com/parts/EDL-2912/
Car: Firebird 91
Can I use this 10166344 retainers with LS6 spings ?
1988iroc350tpi
Aug 14, 2015 07:52 PM
