choke??
Old Nov 5, 2009 | 09:01 AM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
choke??
this might be a dumb ? but does throttle body have choke?
in the mornings my car idles at its 800 rpm and does not warm up till i get to school
i know my 75 p/u with its carb ideled at 1500rpm in mornings and was warm in 5 min
yet my temp gauge dont move in 10 min
what can i do to get this bird to heat up lol
Old Nov 5, 2009 | 09:06 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: choke??
Nope, no choke. All electronically controlled by the ECU and the IAC (idle air control valve). Is there a foil-ish tube running from the driver side exhaust manifold heat shield to the bottom of the air cleaner assembly? My TBI motor sits at 1100 or so and comes down, but also heats to normal pretty easily.
Your not throwing a code for like the coolant temperature sensor or anything are you? Cause that completely confused my car because it didn't know when it was cold.
Old Nov 5, 2009 | 09:10 AM
Car: 84 Trans Am
Re: choke??
idk know for sure id belive not what does that do? for idel?
Old Nov 5, 2009 | 09:13 AM
84redta's Avatar
Re: choke??
Well you would have to check under your hood, that foil-ish tube i was speaking of is for your cold starts and it pulled hot air from the manifold up to the air cleaner to heat the motor up quicker. If that is missing, then you are pulling air from the engine bay, which between driving and if the day is cold enough, would take 10 minutes to get hot air moving into the engine to heat it up. That would be the first thing i'd check for.
As far as the coolant temperature sensor or idle air control valve being defective, you would notice other difficulties in driving the car, among the check engine light being on.
Old Nov 5, 2009 | 03:00 PM
Car: 84 Trans Am
Re: choke??
found that part and it wasnt connected.
but neather was the vacuum line going to the neck of the air cleaner for that valve
does that valve open and shut for hot air to come in if so were is is that vaccum line go so i can reconnect it
Old Nov 5, 2009 | 03:11 PM
84redta's Avatar
Re: choke??
The line is connected there and per temperature as far as i understand, when it's cold it opens the valve, and when warm closes it so that it gets the cold air from the front and not the exhaust manifold. It connects to the TBI unit underneath, i think it's the top middle vacuum port on the front of the unit, but it's been a while since i've been under there. I wanna say there should be a vacuum diagram underneath the hood somewhere, but i'm not sure. But yes, there should be a vacuum line running from one of the vacuum lines on the TBI unit underneath to that valve in the air cleaner assembly to control the valve inside.
Old Nov 5, 2009 | 03:14 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: choke??
hmm well the FIRST thing to check is thermostat. dont over think this problem. see if (when you first start the car on cold engine) you can squeeze the upper radiator hose and feel coolant flow. if thats not it, then yeah dig deeper and try the other suggestions people posted. but thats a dead give away on what to check first when your car doesnt heat up fast enough
Old Nov 10, 2009 | 03:23 PM
Car: 84 Trans Am
Re: choke??
there thermostat is not stuck i can close the radiator hose i reconnected everything yet saw little change???
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
