TBI vs. TPI Torque
Old Jan 9, 2010 | 10:05 PM
srthompson1980's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.27 B/W Posi
TBI vs. TPI Torque
Hey, I was wondering what is restricting the torque on my 305 TBI setup. The 305 with a TBI was rated with 255 ft/lbs, but the 305 TPI of the same year was rated at 295 ft/lbs.
I know all there are alot of differences between the TBI and TPI engines, but is the torque hidden in the heads, exhaust, cam, intake?
Old Jan 9, 2010 | 10:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: TBI vs. TPI Torque
a lot of it would be the tuned port injection itself.......don't know if heads are any diff. Exhaust is the same. Cam is different but small like your tbi cam.
Are you wanting to change it out??
Old Jan 9, 2010 | 10:54 PM
Stephen's Avatar
Car: 87 GTA
The long TPI runners are a big part of the torque TPIs make. Notice how the LT1s are essentially a short runner TPI? The toque # comes down, because of that.
Old Jan 10, 2010 | 01:27 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
The heads are different and in some the cam is different too.
Old Jan 10, 2010 | 02:05 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Exhaust and Tune....Fix BOTH and your TBI will make the TQ of a TPI engine with the exception of the 2,600-3,600 rpm band.
Old Jan 10, 2010 | 06:08 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
TPI Heads are different. TPI Exhaust is alot different, better by much. TBI cam is smaller.
Old Jan 10, 2010 | 10:18 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Some TPI's run the same peanut cam as the L03 TBI. Some run the L98 cam with more duration.
Old Jan 10, 2010 | 10:20 AM
thomas1976's Avatar
Car: 91 Trans am
No 90-92 TPI has the penut cam for sure.
Old Jan 10, 2010 | 10:25 AM
Stephen's Avatar
Car: 87 GTA
Yep. 1987 got the peanut cam. Guess what year my GTA is?
BUT, even with 210,000 miles on mine, I can still roast my 315s so.....
Old Jan 10, 2010 | 09:23 PM
Car: 91 RS Camaro
Engine: 305 TBI
I knew at least 30 h.p. is hidden in the exhaust. Today I picked up a used set of headers and 3" y-pipe and a 3.27 BW posi rear end. After I install everything, I want to get the car to a dyno, and I will see if the torque numbers increase along with the h.p.
After this, I want to try the Edelbrock TBI intake manifold and see what happens.
With 3 kids, this will be a process finding time to install everything.
Old Jan 10, 2010 | 11:01 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Stephen is exactly right.
With headers short headers provide more low end and long headers provide more top end, high speed power.
Intake runner lengths are the exact opposite, short runners provide more high speed power, long runners provide more low end torque.
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
InfinityShade
Aug 22, 2015 08:00 PM
Sanjay
Aug 12, 2015 03:41 PM
