What you putting down with your 5.0TBI
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
who is running 200+ on a 305 TBI
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Re: What you putting down with your 5.0TBI
Not sure but I ran a 15.17 @ 90 with it and its pretty much stock.
Car: 1983 G20 Chevy
Transmission: 4L60
damn i would like to fill this thread to link it on another forum they are knocking my cars potential!
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
is that wheel or crank hp? assuming everything else on the engine being in good working order, all you need to take a L03 to 200 crank hp is a good set of headers, 2.5" or 3" high-flow cat and catback
of course a custom prom tune always helps too, even more so with every mod you add.
of course a custom prom tune always helps too, even more so with every mod you add. Joined: Aug 2008
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
0 hp and 0 tq
L03 threw a rod and then locked up so I have a modified l05 going in soon.
But when it did run it felt like a decent 150 or so for having 98k miles on the motor.
Car: 1989 Camaro RS
Engine: 305 TBI
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
of course a custom prom tune always helps too, even more so with every mod you add.Then again I hadn't driven the car in about three months before I installed everything.
From 170 hp to 200 is almost a 20 percent increase, pretty noticeable.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
of course a custom prom tune always helps too, even more so with every mod you add. Thread Starter
There has got to be more people out there with 200 + HP
I was hoping t osee a format like this
1989 Formula 5.0 TBI
Headers: ----
Heads: -----
Cam: -----
Chip: ------
Total HP : #####
Headers: ----
Heads: -----
Cam: -----
Chip: ------
Total HP : #####
Engine: LS1 / L03
well Thomas, i think for 200 crank hp it's all in the tune once you have a suitable exhaust system
jbucago, the "Chip" row in your format is useless imho. any off the hook chip is not gaining you anything, you need a custom chip. you also still haven't specified whether you're talking about 200 hp at the flywheel (aka "crank hp") or at the rear wheels!
iirc, Fast355 made 400 flywheel on one of his 305 TBI projects. better have a look yourself and browse this forum!
Car: 91 Trans am
I know with the stock LO3 it will take more then exhaust and tune to get that #.
Im talking about to the wheels. im sorry i didnt specify better.. i was hoping for a thread full of proud 5.0 TBI guys bragging about there car so i could use this thread as a link to back me up when i tell my fellow car buddies im gonna build the FREE motor i already have in my Car. They seem to have a nac for telling me its pointless and i minus well drop a freaking 350 in it! Its like sure one day! when im not broke.. they dont seem to grasp that this motor can be built up as well. Beyond 200hp to the wheels.
Car: 1989 Camaro RS
Engine: 305 TBI
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Interesting read, but not practical at all for most of us.
The engine in the article was built with no emission standards in mind and ran on 108 octane race gas.
Neither of those facts are very practical in my opinion.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I honestly couldn't tell you exactly how much power I put down to the wheels but my car is powerful enough to take out tuned LT1 cars, MANY honda's turbo or not, An Infinti G35 a handful of times and a few turboed Jetta's, two SRT-4's and many others. From what everybody tells me my car as it sits is in the very low 14 to high 13 second territory. I have yet to take it to the track.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
My old L03 runs like a raped ape now after all the mods I did to it:
Edelbrock TES headers to 3 inch catless exhaust
ported and polished L03 "swirlport" heads
LT1 .451 lift cam, 1.5 roller rockers
swapped TBI system for fully ported and polished Tuned port system
19 lb/hr multi-tec II injectors(with 8 outlet pintle)
AFPR, bumped Fuel pressure up an extra 3 psi to deal with the cam
descreened MAF
MSD wires and coil
Autolite iridium plugs
dual K&N air filters
timing set to 9* BTDC
3.42:1 rear end gears
It spins the wheels from a dead stop without the aid of the brakes now :P
Ive already taken down a few cars that I couldn't keep up with before, and traction has become the biggest issue I have with it now, need to put a locker in it.
I'm betting it will be even better with a proper tune too!
descreened MAF
MSD wires and coil
Engine: M54 DOHC I6
Axle/Gears: Stock
descreened MAF
MSD wires and coil
descreened MAF
MSD wires and coil
yea there WAS something seriously wrong with it, horse power levels BELOW 250hp MINIMUM, and a 2.72 Auburn posi diff.
im much happier with it now, it revs harder and faster and its MUCH more powerful
Engine: M54 DOHC I6
Axle/Gears: Stock
When I got my RS, it ran on 7 cylinders. It still smoked that one tire lol. If you had a low geared posi, I would see how you may have trouble spinning the tires.
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
when my car was in its prime it ran a 14.9ish 1/4 mile and if i use a HP calculator based on 1/4mile time that puts it at 200 wheel and 240 at the crank. Not bad but i have other things for the future with the setup.
Engine: M54 DOHC I6
Axle/Gears: Stock
What are the specs on that cam? Most LO3's would only be in the 15's with that light of mods! Mine ran a 15.17 on with all stock internals and sticky tires lol.
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Not sure if that was sarcastic or not, but every stock 305tbi I've seen has no problem spinning the tires off the line with a 2.73 open rear end.
My RS dyno'd 133rwhp & 220 rwtq with over 200,000 miles on it. Another RS dyno'd 150rwhp & 220 rwtq but it had headers and a few other minor mod's I don't recall.
The RS has 323,000+ miles on it now and got 33.5 mpg on her last 600+ mile road trip. Orginal 305 & 700R4 only oil,fluid & filter changes etc.
Engine: M54 DOHC I6
Axle/Gears: Stock
I bought my 91 RS new with 4 miles on the odometer. It's a 305, auto w/2.73 open rear end. My RS couldn't spin the tires on dry pavement. Off the line - no spin. Power brake - no spin. Maybe if rev'd to 4k in neutral & slammed into drive the RS would have have.
Hell with mine from even a 20mph roll I can light up the tires, oops what.....i'm not qutie stock anymore,lol
Engine: M54 DOHC I6
Axle/Gears: Stock
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Seeing as how mine is no longer 305 cubic inches...and only at 3 psi of fuel pressure...that and I have no idea what cam is in there or if there is head work or anything else. Boo to unemployment!
0hp/0tq
0hp/0tq
How'd you run that and get those numbers with those mods? I would say you must have a HUGE cam, but you don't mention any cam supporting mods, and it is mild enough to work on a pre-burned chip...?
Engine: M54 DOHC I6
Axle/Gears: Stock
I had a bunch of suspension stuff done but i also think it was the really cold weather that morning. On hot days she ran low 15s all day. I have a few ultimate TBI mods and spacers and open element and higher fuel pressure. Theres alot not in my signiture anymore since the car is a metal shell now. Id have to look up the cam its been a while but i think it was slightly bigger than the LT1 cam when I was researching all this.
yes it was a 2.72 POSI differential. as for MPGs? Im putting down 16-17 city 25-27 highway, its about as much as my buddie's northstar does on gas. with the 3.42 and the mods ive done to it, it REEALLY slaps you into the seat now.
Engine: M54 DOHC I6
Axle/Gears: Stock
What's your gas mileage with 3.42's? And what rpm is it at at 60?
Engine: LS1 / L03
wow, i never noticed 60mph is about at 950 rpm with the 2.73 gears! Oo
with 3.42 it should be about 1150 rpm.
with my totally stock L03, 700R4, 2.73 and nothing than an EBL with stock tune i managed to get about 23mpg at a 300 miles trip driving 90 to 100mph.
Car: 1984 camaro z28
Engine: 305 H.O.
Transmission: 700r4 automatic
well i actually found a site that had seriously brought out the 305s potential. ive got it saved here somewhere lol but the ended with like 300hp outta almost( i dont remember the actual number could have been more) WITH OUT turbo or supercharger. if some one really wants it hit me with a private message and ill send you the link( if i find it XD) btw im almost pushing 200 lol with minor mods
Car: 1990 camaro rs
Engine: 305 tbi
mines completely stock and it'll smoke tires half way down my street no problem, and it has 115,000 miles on it, but mabye its the way you take care of the engine too, cause the owner before me, myself being the second, changed the oil every 1000 miles and the engine is clean enough to eat off of and he was a cop so I know he was nice it, so mabye care is a factor too
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
My L03 is mated with a T5, so there's no problem smoking tires there.
In fact, if I'm making a turn from a stop it almost always spins that inside tire a bit, probably because of the fact that it's a non-posi rear end.
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
https://www.thirdgen.org/forums/sout...our-car-2.html
https://www.thirdgen.org/forums/theo...initi-g35.html
Here's to thread's that have some good pics of the car. Enjoy.
Car: 90 formula
Transmission: auto
on the dyno stock i put down 225 rwhp 334torque
ran veryy low 14 in the quarter
but then again i dont have alittle ol 305
3fifity tpi with a tad of suspension work but right now im in the works of the intake swap.
but it was no where that quick stock when i got it. pretty much replaced everything and 20ish oil changes til there was no sludge or anything in the oil valve covers etc
Engine: LS1 / L03
seems like many in here don't know what has been achieved.. so i'll go ahead and post a thread of one of those builds: https://www.thirdgen.org/forums/tbi/...ack-times.html
Car: 89camaro rs
nice car bro , u have a pair to strip the car out like that. i wish i could do that .
i love ur engine bay, wat was the most hassle in gutting the engine bay out like that?
Honestly the hardest thing to do in the engine bay was the gutting of the factory harness. It took me a week to figure it out and in all honesty it's still not as clean as I'd like it to be.I think that when I finally do an engine swap I'm going to finish it up the way I want it. Everything else for me was just "trial and error" really. I have some old pics saved on my computer that I'd like to put up in another thread as a "stages through time" kinda thing.
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
my 1992 Firebird has about 220,000 miles and had a engine and tranny rebuild, but only to stock specs....it wud haul more *** if my tires wernt so slippery from all the burnouts XDD but i think my bird has atleast 180 cuz she does haul some ***
Car: 89camaro rs
bro ur tempting me so hard to gut everything out my engine bay and just have it as purpose car ( or at least the engine bay).
get some caster and camber plates.
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
With my L03 at 160k miles, I decided to ditch the swirl-ports for vortecs and ditched the stock cam in favor of a Lunati voodoo cam with just over .500" lift, Duration @ .050" is 211 intake, 219 exhaust. Also running a single plane summit intake manifold.
Tuned with EBL, not perfect but pretty well, made a smokey 243hp and 250ft/lbs of torque on dyno day last year, had a perfect 12.8 AFR dialed in at WOT.
Best time of 14.2 @ 99mph with a lame 2.1 60ft.
The engine was finally pulled for burning to much oil, and I have about 800 miles on my freshened L31 vortec 350 right now with the same heads and cam. I should for sure be in 13s now, and hoping for around 285RWHP.
Will find out this summer!
