Sweating Throttle Body
Old Mar 10, 2010 | 04:23 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I got the 327 built and the TBI modded as far as I could go. Ultimate TBI+ boring out to run the 52mm TPI plates.
After idling for 2-3 minutes after startup the TBI is cold enough to have just come out of the freezer as well as forming condensation. I know that has a lot to do with humidity, but does this happen to anyone else? I've never noticed it until this point.
I understand the principal of a gas moving from high to low pressure will drop in temperature(Air Conditioning). Should this lead me to believe that I have good vacuum at idle and could have gone with a larger cam?
Old Mar 10, 2010 | 01:48 PM
Ronny's Avatar
Re: Sweating Throttle Body
I would ignore it. It happens to me as no heat whatsoever to TB unit. In fact I think ice buildup caused my throttle to stick. That was a cool day. Some snowmobile carbs send coolant heat to carb to prevent that.
Old Mar 10, 2010 | 02:47 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
On truck BBC TBI uses a heated Q-Jet to TB cast iron adapter plate with coolant passages for quicker heat equalization. I have seen carbs ice-up, but since I live in warmer clement I do not see this anymore.
//RF
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
