5.7 tbi
Old Mar 16, 2010 | 05:52 PM
ewalker85's Avatar
5.7 tbi
I just acquired a 89 suburban that has a Jasper 350 5.7 tbi. I will be putting the motor in my 87 Monte ss.
My question to the 3rd gen community...
What are some simple must do's to pull some extra hp. I'm more of a paint body guy but have someone doin the motor work. I just wanted to come to the place that specializes in these kinds of motors
Old Mar 16, 2010 | 05:55 PM
grassyflats's Avatar
Re: 5.7 tbi
put a tuned port injection intake and harness on her
or some guys like the HSR holley stealth ram intake...i have one
Old Mar 16, 2010 | 06:06 PM
ewalker85's Avatar
Re: 5.7 tbi
I have a tpi unit I was thinking about using. And a set of heads. But I have to run the numbers to find out what they are. Dunno if I will use it tho.
I would like to find a nice came that will give it a pretty radical lope. But from the research I've been trying I guess it's pretty imperative to get one that matches everything with the tbi.
All suggestions apperciated
Old Mar 16, 2010 | 07:00 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: 5.7 tbi
Depends what "some extra hp" stands for. A mild cam, anough fuel and a decent tune should make 250rwhp easy.
Personally I would pull the heads and check piston to deck, and inspect the engine internally and make sure everything is fine, before installing.
Swapping TBI or TPI alone is probably not going to give lots of gains, just pick the easyer or available.
The HSR will probably only make more power in the rpm's were a stock rebuilt engine starts to desitegrate.
Old Mar 16, 2010 | 07:16 PM
ewalker85's Avatar
Re: 5.7 tbi
Like I said forgive my ignorance on the engine knowledge. Any exact
cam suggestions would be helpful.
Old Mar 16, 2010 | 07:20 PM
thomas1976's Avatar
Car: 91 Trans am
Re: 5.7 tbi
First you need to look in the engine to find out if roller or flat tapped.
Old Mar 16, 2010 | 10:56 PM
ewalker85's Avatar
Re: 5.7 tbi
flat tapped
Old Mar 17, 2010 | 04:49 AM
thomas1976's Avatar
Car: 91 Trans am
Re: 5.7 tbi
According to comp cam quest 6, #12-256-4 should work nice. Mabe you should play with it a little too.
I just noticed a average of 30hp loss using flat tapped vs roller. You will need headers and probably nice heads too for 250rwhp.
And make sure you have a good quench.
blackz281le
Jan 11, 2016 07:51 AM
86z89iroc
Oct 5, 2015 01:04 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
