Edelbrock tbi intake
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hi I been wanting to upgrade my intake and been thinking of getting a tbi intake for my car but not sure if it would actually make a difference or should I spend my money on other mods like a cam.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Edelbrock tbi intake
cam would be better but intake has to come off to do cam. save up and do both at one time. include a new double roller timing chain at the same time
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I'm building a 350 little by little right now I am just looking for a cam and an intake. Would a lt4 not hot cam work good with this intake or it won't make a difference with the stock one.
I am a noob at this so don't know much about this.
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
I agree that as long as you have the Peanut Cam in the stock 305" TBI it's really hard to advance the performance. The Edelbrock 3704 Intake is good , but without some mods, it won't help much. A good Air Cleaner Setup and Performance Exhaust will help more until you can change the cam.
Checking the Message Forums Search on TBI's will give you a lot of info. Don't get to radical on the cam or you will have a nightmare trying to tune it.
If you can find a good used LT1 cam would be the cheapest but are hard to find now.
Lunati has a good roller cam #LUN-50142 from Summit Racing, but it's expensive, about $290 bucks.
CFM-Tech Ported Throttle Body #62-350 is also a good mod, but is about $230 bucks. Takes the CFM's from about 480 to 620. There is a thread on this forum that tells how to port the Throttle Body yourself, but be careful, you can screw it up.
Good Luck with your ride...
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Car: check
Engine: check
Transmission: check
The Edelbrock 3704 TBI Intake is a stock replacement. It isn't worth the time to even swap it on for the stock GM TBI intake.
For a step up in intake manifolds, look at the Holley Pro Jection TBI intake, or use a carb intake with an adapter plate.
Do some searches here on this board for tons of threads discussing intakes manifolds for TBI set ups.
RBob.
RBob.
Car: 85 Camaro S/C
Dido on the searches, won't argue about the Intake. Will he have to use a Holley TBI to match the Holley intake? Is the ports bigger?. Maybe you can answer his question about the LT4 Cam.
Car: check
Engine: check
Transmission: check
Check out the sticky's above for the budget build up, along with the performance upgrades thread.
With a cam on a stock L03, or any stock engine, watch the lift. Unless you want to get into head work that is the first qualifier for a cam.
RBob.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Thank You very much now i am understanding more about what to do first i am gonna save up for other parts that will actually give a better boost thanks robertfrank.
Not a problem man, it's how I roll,lol I do need to do some updates on that thread though, it's been a while.
86IROC112
Aug 17, 2015 02:00 PM
