Vortec head swap questions
Old Aug 26, 2010 | 04:08 PM
morgsie's Avatar
Hey guys, getting ready on swapping my 355 w/ Vortec heads into my car this Fall and had a couple questions:
1. I will be going with a 454 TBI and using a square bore intake. I will need an adapter plate, the question is do I get a front mount or rear mount adapter plate? (I have not been able to find a center mount BB adapter plate btw.) Will be using this intake: http://www.summitracing.com/parts/PFS-52028/
2. What do I do about the TV cable bracket? Can I just modify the stock one to fit the Vortec intake by boring the holes out and doing a bit of bending? I am worried about TV cable geometry. This is also why I am wanting to know which adapter to go with.
Was hoping to order my intake and adapter plate next week, then I can do a mock up on the engine stand. Thanks.
Old Aug 30, 2010 | 11:58 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Vortec head swap questions
last time i had checked, i believe the holley one can be done either way (bolt provisions for front or rear). i've got one in the toolbox not being used, so i can double check for ya.
as for the geometry, i'll have to leave that to someone else
Old Sep 3, 2010 | 03:23 PM
morgsie's Avatar
bump
Old Sep 3, 2010 | 03:49 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Originally Posted by morgsie
Thats not a great intake for TBI, A heated one works better.
Do yourself a favor and check out dctrumpet's store, he is also member here and drives TBI.
http://stores.ebay.com/TBIPARTS/_i.h...4.l1581&_pgn=2
Old Sep 4, 2010 | 11:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
ok, finally dug out the plate I previously used
as you can see, provisions for both square and spread bore intake bolt patterns and 2 sets of install holes for the tb (one set's got studs in them to block vacuum leaks, but they're just in place with blue loctite).
think it may be of use for your setup?
Old Sep 7, 2010 | 08:50 PM
92 rs pit's Avatar
new here, just picked up a 92 rs 305, i plan to put a 350 in it over the winter and was just wondering, is it possible just to take a complete vortec motor and heads and swap them into my tbi? i understand that you have to buy or make an adapter to swap it, but thats all that needs to be done to switch to vortec? i have not picked up a motor yet, not sure what i wanna do, would like to put a vortec in it... i think, and the other thing is i believe its a 4l60 but keeping it tbi and chipping it for 350 that would be ok also? my brother is going to rebuild the tranny and shift kit and stall in it.
and another thing can i put vortec heads on a carb or tbi motor? just change the intake? nothing to do with the cam or anything like that? im sorry to sound like i dont know much but lets face it... i dont
Old Sep 8, 2010 | 04:24 AM
thomas1976's Avatar
Car: 91 Trans am
1. Read all the Sticky Treads on top of the forum. The "BUDGET TBI BUILDUP" tread answers all your question.
2. Do not start new topics in other peoples treads.
Old Sep 9, 2010 | 03:25 PM
morgsie's Avatar
I thought all dual-plane intakes were heated...
Old Sep 9, 2010 | 04:09 PM
thomas1976's Avatar
Car: 91 Trans am
The one in your link is not.
Old Sep 9, 2010 | 08:16 PM
morgsie's Avatar
How can you tell? Is it because of the coolant ports at each corner?
Old Sep 10, 2010 | 04:01 AM
thomas1976's Avatar
Car: 91 Trans am
No coolant circulates around the runners and plenum.
Old Sep 20, 2010 | 02:31 PM
morgsie's Avatar
What would be a good intake to run? I currently have the GMPP Vortec/TBI intake, but from what I have read it is really only good for a stock engine. It also would have to be bored out to accept the 454 TBI. I am currently hoping to put 300HP to the wheels. I really would like an intake that has a coolant port on the rear-passenger side, which alot of them do not seem to have.
Old Sep 21, 2010 | 07:16 AM
thomas1976's Avatar
Car: 91 Trans am
The GMPP TBI intake should be ok for 300rwhp.
Old Sep 21, 2010 | 02:36 PM
morgsie's Avatar
I was talking Brian at TBIchips and he said that the intake would restrict power some. He recommended going with the Edlebrock RPM intake, but isn't that one not heated as well? I'm thinking I might just keep the GMPP intake and upgrade to something else in the future. I am actually wanting/planning to go to a MPFI setup in the future anyway, it is just way out of my price range ATM. Does anyone have flow #'s for the GMPP intake? I can't find any.
Old Sep 22, 2010 | 10:12 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I think the standard RPM intake is heated. What you need to stay away from is the RPM Airgap manifold when using TBI.
Not a bad idea. You can always upgrade later and you could sell that intake to pay for another pretty easily.
Old Sep 22, 2010 | 02:13 PM
morgsie's Avatar
I am actually trying to sell the GMPP intake ATM, but no takers. Maybe it's cause I'm in Canada or am asking to much ($300 OBO)...
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
