CFI Water Outlet/thermostat Housing
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I cannot find a crossfire injection water outlet/thermostat housing. Every one I found does not fit and the hose neck angle is way off.(napa, oehq, rock auto, and etc) it keeps hitting the a/c compressor. Does anyone have a CFI theromostat housing or know a suitable replacement?
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: CFI Water Outlet/thermostat Housing
Call the folks at Mid America Motor Works, http://www.mamotorworks.com .
They can probably hook you up with a cross fire vette t-stat housing.
bump
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if nothing turns up could possibly have a welding shop
weld up the original housing.
Engine: gone
Transmission: gone
Axle/Gears: gone
is thier something really special about it? You couldnt purchase one of those SBC adjutable thermostat housings you adjust to the position you need?
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
These aren't the best shots, but they will give you an idea of what it looks like.
The green wire in one of the pictures is currently holding up the power steering pump, as I have removed the support and pulley to do some other work.
The Part Number is 14064012, and it is specific to the LU5 engine only.
Last edited by 82CrossFire Z28; Sep 13, 2010 at 01:30 AM. Reason: added part number
Engine: gone
Transmission: gone
Axle/Gears: gone
Well a chrome one doesnt care if your car is a daily driver or not. Buy chrome sand it down some paint it black and be done with it...you dont have to make it as difficult as you are.
Kitt
I don't know if you saw the thread in the History board re the Firebird DT500 pace car that is going to the crusher? It has a CFI in it and the owner is trying a sell parts off of it. If you contact him quick you might get lucky.
Sorry, i don't have the link to the tread handy.
Kitt
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
interesting the t-stat housing on my 82 is painted gloss black. Looks to be original, but I don't know for sure.
