1' swirl TBI spacer and 2' air filter or no TBI spacer and 3' air filter?
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
So, as of right now I got a TBI 305 with a 14 by 3' K&N cloth filter open air element (with open top also). A friend gave me a 1' TBI spacer with swirl design that wouldn't fit on his truck. My air element almost touches my hood, so in order to add an inch below the TBI I would need to remove an inch from my filter.
Is it even worth it? Wouldn't the inch smaller filter bring total air flow down below what it is now even with this TBI spacer that probably doesn't even help air flow in the first place?
My guess would be no, not worth it, but figured I'd at least ask before throwing it away. Also, when I get my cowl hood I'd have the space to pop the TBI spacer on without getting a smaller filter, would it be worth it then?
Thanks for any info!
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 1' swirl TBI spacer and 2' air filter or no TBI spacer and 3' air filter?
You know I have not installed one on my car yet. But if I did find one cheap enough I would try deffinately. Now I'd rather have the 3 inch filter over the 1 inch spacer. But in the future if you do get a cowl I'd change and see how it does.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have found mixed reviews on the spacers. From what I have read and heard I would not sacrifice filter for a spacer. I would save it for when you get your cowl hood then give it a try.
Car: 88 Camaro
Axle/Gears: 4.11
@ronusmcmma
Did you always have that hood or did you add it on yourself? I'm trying to figure out if when I get mine, it's gonna come down and cover my filter as is or if I'm gonna have to raise the filter to get it to sit in that hole with the hood closed.
Engine: gone
Transmission: gone
Axle/Gears: gone
I know a 14 inch cleaner wont clear my hood using the hypertech powercharger also
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
googled.
> http://www.jegs.com/i/Hypertech/533/...oductId=746434
> http://www.jegs.com/i/JEGS/555/50080/10002/-1
From what it shows it basically looks like it diverts the engine bay air and if you have a cowl it seals it just right to suck only the air from the cowl hood?
IF that is true, how high does this sit? I have a tbi w/ cowl, i was looking into something like this. Please post pictures of your setup an how it works please? thanks!
Engine: TBI,5.0
You seal the air filter from underneath with a air tray.That is a Goodmark steel hood that I bought about 3 years ago just befor getting the car painted.
You can get cool air being pulled/pushed through the cowl opening with a X-Stream filter top. Thats all I'm doing with mine. Only the filter top and a small amount of the other filter fits inside the cowl hole on mine. A lot of the cowl hoods out there don't have a round hole like mine. Most I have seen have a large opening at the windshield and gradually slope to the front remaining open the hole way down. I would amagin if you had a hole like mine with a tall enough cowl you could raise the filter into the opening if you wanted. Ether way I recommend the X-Streem filter top for any cowl. Heres one more photo of my hood.
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I have the same hood Ronus. I cut out the back of it where all the little holes were to make it open though.
Engine: gone
Transmission: gone
Axle/Gears: gone
googled.
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh yeah I have since removed the nipple in the powercharger and located my Intake air temp sensor there. Just used some epoxy to hold it in. Nothing fancy no one is going to really be seeing it.
Engine: TBI,5.0
UnderCover89TBI,
What did you use to cut the cowl opening? Do you have any photos?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I was hoping that item was something like this.
I want something to surround my air filter and have a stripping like this that can press against the hole that the filter sits in to make a nice seal so only air from the cowl comes in.
Also does that item even work? or is it pointless? that we were discussing earlier
Engine: gone
Transmission: gone
Axle/Gears: gone
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Yeah eventually my plan is to make something like that also. making some sort of air box with foam or rubber that seals against the hood when down. I felt an increase when I installed the powercharger. I moddeed the air cleaner, installed the charger, and put a flow through top on at the same time. You can hear it sucking like crazy.
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah especially since jegs makes one for cheaper ya know that's more worth it. I cut the bottom of the air cleaner out though.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Engine: gone
Transmission: gone
Axle/Gears: gone
look at my pics i posted that is not the factory hole on the bottom of the air cleaner. I did not see a point in "unshrouding" the injectors and having a hole that doesn't really utilize the bowl deisgn.
Engine: gone
Transmission: gone
Axle/Gears: gone
here's a shot of the back of my goodmark cowl hood I cut out the center as seen
Engine: TBI,5.0
You know what ? I really like it. I have had basically the same idea but have to tell you that its looks like a fairly easy job but I have found with this car nothing gos easy. Man I just have that leave it alone for awhile syndrome. And with the new paint it just worries me. Can I ask you about rain? Do you find it to be a problem at all?
Engine: gone
Transmission: gone
Axle/Gears: gone
Umm rain is a non factor. little droplets will go in there but that's about it. I have not seen any problems from it. I just figured a bigger hole will take in more air and let more air out and I thought all those round circles looked tacky. Well I had the hood off and I used an air saw with a flexible blade and just cut away.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
very nice man. i might end up doing the same and then ill put the xstream filter on.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 88 Camaro
Axle/Gears: 4.11
Is there anything (direct bolt on) we can buy that can kinda seal our air filter area to the hood like they did with the old school cowl setups? Kinda like this...
What about a powercharger, think that would work with a bit of modification to seal to the hood?
Engine: gone
Transmission: gone
Axle/Gears: gone
well the powercharger is not big enough to do that so deffinately not.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
about $50 when your done, but seems to be worth it to trap the warmer air away from it. Supreme Member
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I am going to do something like that. With the xstream lid on the filter. Should work well.
ok here is my air cleaner if i get the power chargerwill it go in the air cleaner or wht im confused on how i wuld set it up
Engine: gone
Transmission: gone
Axle/Gears: gone
it would go beneath the air cleaner and then the air cleaner would mount on top of it. should work I guess. Its just the hole for the air cleaner isnt nearly as big as the powercharger.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
advance auto parts sells spectre air cleaner, complete with top air filter, aoe 14" air filter with carb/tbi bottom plate for $70, which is awesome, k&n for all the parts to complete this makes over $200, it has 1400cfm rating as well, still want to make a dish plate though like in the 60s camaro picture posted.
Engine: TBI,5.0
OK, I found a site that has all kinds of cowl components. Its Goodmark .If you punch in "cowl" in the "keyword" search box then go in to about the 4th page they start to show parts for cowls.You have to dig a little but the parts are there. Or maybe call them and they can give you a part # on what your looking for. Here's the link = http://www.goodmarkindustries.com/
Engine: gone
Transmission: gone
Axle/Gears: gone
I dont really see anything on there that will work good on our cars.
Engine: TBI,5.0
I just thought maybe some one that can fabricate could use some of their stuff.
It was asked were to get cowl parts and Goodmark is it.They may not be exactly perfect for our cars but that's were the fabrication comes in.
Engine: gone
Transmission: gone
Axle/Gears: gone
I gotcha man. I think I misinterpeted your original post. I thought they had stuff distinctly for 3rd gens
Engine: TBI,5.0
We have one or two guys on TGO that have made their own bottom tray and used that with some fire retardant foam around the top to make the seal.Maybe one of those guys will see this and add some info. They do sell the actual cowl air cleaner rubber seal on Goodmarks web page.
Engine: gone
Transmission: gone
Axle/Gears: gone
If you have a summit catalog they have a tray designed for use with hood scoops located in the scoops and hoods section its a metal sheet with foam around it im sure that could be fabricated. I really like the design of the one posted above. If I decide to utilize my cowl in that design then that's probably what I will imitate. I still kind of want to do a CAI kit
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
