Stuck switching TBI to carb
Old Oct 5, 2010 | 05:57 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, Right now my 91 is a TBI car, the 305 is on it's last legs, literally. So, I've been re-doing a 1978 350, out of a vette, with different heads ofcourse..
Anyway, reading the tech article, it says I have to get a replacement dizzy. Why is that? Why can't I just use the one for the TBI?
Old Oct 5, 2010 | 02:01 PM
morgsie's Avatar
Re: Stuck switching TBI to carb
TBI dist has no mechanical advance.
Old Oct 6, 2010 | 12:17 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yes so if you are using the tbi system with its computer you would not have too. But since your going carburetor you need a HEI vacuum advance or mechanical advance. Luckily you can get one fairly cheap if you dont want a MSD or Mallory distributor. Even those can be had fairly decent price. Not interested in keepign your tbi? you will get better fuel mileage, a little less overall power. Still respectable.
Old Oct 6, 2010 | 01:37 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
a well tuned TBI will make almost the exact same power as a carb the power difference is negligible. another nice advantage of efi in general, is that you get knock protection.
Old Oct 6, 2010 | 05:40 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
No.
Old Oct 7, 2010 | 06:41 PM
Kevman's Avatar
Engine: 2004 LQ4
Well, I'm looking at getting around 300 horsepower, could the TBI do that much?
Old Oct 7, 2010 | 08:45 PM
ericjon262's Avatar
No problem, check this out.
https://www.thirdgen.org/forums/tbi/...ack-times.html
Old Oct 11, 2010 | 12:11 PM
Kevman's Avatar
Engine: 2004 LQ4
Found a HEI dizzy that drops right in, $130 from MSD, I found a 2101 Eddy intake in my garage thats square bore and spread, saved me $140, all I need is a carb, probably a spreadbore 600 Holley..
Old Oct 11, 2010 | 06:42 PM
ericjon262's Avatar
well, if you're gonna go the carb route, you should probably post up on the carb boards, but I'll tell you, after owning both carb, and EFI vehicles, I won't ever own another carb vehicle. if you can show me a carbed 454 crew cab dually truck that gets 17 MPG without overdrive and with 4.10 gears, I might consider going back to carbs.
Old Oct 11, 2010 | 11:05 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
no overdrive in your R30 eh? impressive! is that hauling or empty?
Old Oct 11, 2010 | 11:22 PM
ericjon262's Avatar
it's a turbo 400, so it goes to 1:1, and that's it. I got 17.2 miles per gallon, over 8.2 miles, keep in mind though, traffic was almost non existent, and I was just cruising, I get about 16 MPG Hwy, going about 65-70 and that was empty... well, as empty as a crewcab dually with and 8 foot bed gets!, I'm still working on the tune though, so it could get better from here.
Old Oct 12, 2010 | 04:21 AM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Thats prolly as good fuel milage that more modern efi trucks with smaller engines get lol, thats good.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
86IROC112
Aug 17, 2015 02:00 PM
