Poor top end pull, idle stumble, trouble with timing
Old Oct 13, 2010 | 08:38 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
92 Firebird, 305 E, TBI. Complete rebuild with mild comp cam (XR258H). Stock heads, stock TBI, no air pump, gutted converter. Has the stumble on idle as in other threads, but only when warm. No engine codes with the stumble, but getting worse and sometimes dies in gear. Pulling 17 in Hg from front of TBI at base. Have had trouble with the timing due to idling problems. Car starts easily hot and cold. High RPM performance not there. Put new fuel pump in tank (Airtek) but am questioning quality of pump.
Eventually threw codes 15, 32, and 34. Since the rebuild (about 600 miles), I have replaced the coolant sensor, EGR valve, MAP sensor, new distributor, new MSD wires, new MSD coil, new distributor cap, new IAC, new non-adjustable TPS, new TBI gaskets (fuel inj are several years old)in addition to all the new internal parts (even down to new camshaft bearings).
My question is what to check next? I am pulling out what little hair I have left.
Old Oct 13, 2010 | 08:45 PM
jwande's Avatar
Engine: 305 TBI
Re: Poor top end pull, idle stumble, trouble with timing
Sorry - forgot I replaced the O2 sensor as well.
Old Oct 14, 2010 | 05:25 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
What part #?
Old Oct 14, 2010 | 05:22 PM
jwande's Avatar
Engine: 305 TBI
08-500-8
Old Oct 14, 2010 | 06:57 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
ur problem might be on the cam i guess, the stock tune might not be happy with the aftermarket cam on it.
Old Oct 15, 2010 | 04:20 AM
thomas1976's Avatar
Car: 91 Trans am
08-500-8
480/488 lift, 112 lsa 206/212 duration.
Tha's a nice cam I have that in my 360 tbi.
Stock heads do not allow that much lift, a set of TFS 175, more fuel and EBL flash to tune it should turn that 305 in to a wery fun engine.
Old Oct 15, 2010 | 09:44 AM
jwande's Avatar
Engine: 305 TBI
The Competition Cams Tech said that I wouldn't have to change the computer program. Now I am concerned. BTW - what is EBL, LSA, and TFS? I am old school on rebuilds (mid 70's engines). My son and I just finished this and it is his car.
Old Oct 15, 2010 | 12:44 PM
DSGx's Avatar
Engine: 305 TBI L03
The EBL is a replacement ECM develop by a member here, its the best thing to tune for TBI , its faster for datalogs and easier to use all around, u dont have to burn chips or anything , just plug your laptop to it while its in teh car and tune away, here its their website http://www.dynamicefi.com/.
LSA i think its Lobe Separation for the cams, im no expert on that but thats what i think it means or close to that.
TFS i think he means aftermarket heads that come already with small combustion chambers so they are like direct bolt ons for 305s.
Old Oct 17, 2010 | 07:13 AM
jwande's Avatar
Engine: 305 TBI
Fuel pressure is 13 lbs at the filter. Has anyone ever set the valve lash on these roller cams when it is running? I used to do it all the time in the old days - feeler gauge under the rocker...........(Comp Cams said to just set the lash when cold).
Old Oct 18, 2010 | 04:51 AM
thomas1976's Avatar
Car: 91 Trans am
Only andjusted the rockers with the engine off, as described in the GM service manual. Works wery well.
What did you do about the lift of the new cam on the stock heads?
This is the best to tune and run a modded TBI engine http://dynamicefi.com/
Old Oct 18, 2010 | 07:51 AM
jwande's Avatar
Engine: 305 TBI
Went with new springs that had more force, got rid of rotators, made sure installed height was in spec
theshackle
Sep 17, 2020 08:26 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
wayshegoes
Aug 17, 2015 12:00 PM
