is it my computer? which box is it?
Old Nov 9, 2010 | 01:46 PM
proj88formula's Avatar
Car: formula
Engine: 305 tbi
Axle/Gears: Ls1 3:42
so i have a 88 formula with a 305 tbi. a few years ago while driving it shut off on its own. it took a while to start but it did, got down the street and it died again and would not keep running. it would start and run just fine till it was put into gear, (its an automatic) or if it hit operating temperature. i have tried replacing the throttle position sensor, egr, and a few other things that i can no longer remember. its been a deployment since then and a few years getting everything back in order till i could work on it again. completely stumped. and i have no idea about electronics. so please dumb it down a little, thanks guys. james
Old Nov 9, 2010 | 06:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: is it my computer? which box is it?
Can you hear the fuel pump whining when it's running? With key on? Have you changed the fuel filter?
Old Nov 10, 2010 | 09:18 AM
Car: formula
Engine: 305 tbi
yes the fuel pump whines when the key is turned to the on position, and yes i replaced the fuel line fuel filter. i did not go any farther with that the reason being the car was getting enough fuel to start and run untill it was put into gear or reached operating temperature. is there something i might have missed? thanks for the ideas, james
PurelyPMD
May 5, 2016 04:57 PM
WejaZ28
Oct 3, 2015 07:38 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
