l03 engine, l31 cam?
Car: 1988 Formula Firebird (deceased)
Engine: l03 V8
Transmission: T-5 manual
Hello, I did my best to scour the message boards and I'm sorry if this has been asked before but I have an 88' Formula bird with the l03 305 and was looking to put some more horse in her. I was wondering if you could put a l31 cam in without any/many problems and what kind of heads I should get to support the system.
The total system I plan on *eventually* putting in is hooker headers, high rise/dual runner intake manifold, new cam (idk what one yet) and new ported and polished heads (also don't know what kind yet) along with a new cat back dual exhaust and some form of ram air intake
I'm new to the site and new to the muscle building scene so i'm sorry if some sh*ts effed up, or i don't know much.
Thanks alot in advance
Re: l03 engine, l31 cam?
The general cheap cam swap on here for the L03 is a LT1 cam. It has a lot better specs to it then the L31. Either one you will have to do computer tuning or change to a carb and tune it. The L31 cam isnt much bigger than stock. It may run ok with stock tune, but I don't think it would be worth the time of swapping it for the minimal gain. You can usually find a used LT1 cam for under $50. I'd say the vortec heads are one of the best values out there at about $600 for a complete set. Which is what I went with. That combo with good intake and exhaust setup can get you close to 300 hp at the crank. You could always go bigger and better but that's a decent setup.
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Before doing a cam swap you should have a full exhaust ready to take full advantage of it. If you start with headers, high flow cat and catback you will notice quite a gain from that alone and really dont need to worry so much with computer tuning until later. A cam swap is much more involved and will require you to learn much more and tuning will become an issue.
Car: 1991 RS Camaro
Engine: 350 TBI
Also, if planning to go with vortec heads it may not be a good idea if you need to pass strict emissions. EGR may become an issue if you need to pass smog and will require a more expensive manifold and some fabrication. If retaining EGR is not a problem they are a good option.
Engine: l03 V8
Thank you for the help!
Engine: l03 V8
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Do some more research on the site and poke around in the tech general/tbi forum. Heads and cam swaps on a 305 will give you more power but the easier alternative is to drop in a 350. 3'' exhaust from the cat back is fine for the car and hurt anything. Before you consider a cam swap get your headers and that end dressed up to make the most out of whatever you choose.
Engine: gone
Transmission: gone
Axle/Gears: gone
Its against federal law to remove or modify converter. Not that I care just letting you know!
Yes the LT1 cam will pretty much drop right in. Only mod to the cam is you need to make the dowl pin on the end of it the same length as your stock cam. Any aftermarket catback will work, just pick your sound and go. If you dont have emissions then nobody will be checking your cat or emissions equipment. But you will not find a shop that will touch it though, gotta figure that out on your own.
You have to get into prom tuning to do it on your own, or take it to somebody. I got tired of it and ditched the tbi for a demon carb. Plus everything I have put on my 305 will directly cross over to a 350 if the 305 decided to let go, so I'm just running it until it dies or has a major issue. But it loves 6k rpm everytime.
If you're sticking with the stock heads then the LT1 cam is good for you. From my experience though I wouldn't even bother with a cam that small after going to the ZZ4 cam. It really isn't that hard to tune in and the power increase is very nice. Then again I did the whole Head cam and intake swap at the same time. Plus, go to page 3 of my cardomain and read up. I'm not typing all that mess up again,lol
Engine: l03 V8
Out of curiosity what kind of gas mileage do you get with the zz4 cam and vortec heads? Also what do i need to use to tune the car once i get it all?
Engine: l03 V8
So the current setup i'm looking at is LT1 cam, vortec 059 heads, Hooker darkside headers and a 3704 intake from edelbrock.
Do you think that will all work together? also how much HP do you think i'll land at. i'm hoping above 220. What equipment do i need to start tuning?
1 Post
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
you should make well over 220 hp close to 300 at the crank
Engine: l03 V8
sweet!, about how much does that translate to at the wheels?
Also do you think all of the head and cam will fit together in the intake and block and all that without too much machining? I'm very new to the scene and would like to do as little custom fabricating as possible for my first cam/head/intake swap
Car: 1991 RS Camaro
Engine: 350 TBI
I agree it should put you around 280 or more at the crank if tuned well enough. I had planned to do the same setup, but have changed it a bit. The 3704 intake is not going to bolt up to those heads. You will need a vortec specific intake. Its probably best to find a vortec carb intake and get a TBI adapter plate. There is only 1 TBI vortec intake from GMPP and its around $400.
Engine: l03 V8
If it doesn't fit what can i do to get a little more hood clearance?
So in total i should get a vortec 059 (305?) heads, LT1 Cam and a performer RPM intake from edelbrock with a carb-TBI adapter plate?
Car: 1991 RS Camaro
Engine: 350 TBI
You have many options. You could play with shorter air cleaners & drop bases. Change your hood. You could also go with a low rise vortec intake. There are many to choose from like the regular Edelbrock Performer Vortec (shorter than the RPM), Weiand, Professional Products Cyclone, Summit, etc.
I have the stock intake with a 3" x 14" open air cleaner and my wingnut hits the hood insulation with the stock hood.
Car: 1991 RS Camaro
Engine: 350 TBI
I'd do a full exhaust with headers back first. Once you have the rest of your parts you may want to look into the EBL to tune the combo. Probably the best way to go.
Engine: l03 V8
Whats an EBL? Also one thing i was curious about, what kind of gears should i get, I was thinking 3.73, I want to gear it mainly for gas mileage but off the line i would like to boil some tires if necessary
Engine: l03 V8
Also does anyone have any idea where the "spid" sticker with my "rpo" codes are? i looked in my console box and in my rear lock box i seem not to have them....
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
the L31 cam is the B-body lt1 cam.
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
honestly, it sounds like you have a lot to learn before you go messing stuff up. a cam and all that other work is very intensive and does require experience and knowledge.
Engine: l03 V8
I'm going to be having someone who has done cam swaps etc before help/watch over me while I do this but I want to make sure the stuff I picked out will work together. What better way to learn than by doing?
Car: 1991 RS Camaro
Engine: 350 TBI
Most people around here are running a 3.73 or 3.42 gear. Performance is around the same with the 3.42 probably getting slightly better mileage. I personally like the 3.42 gear and will go to it sooner or later.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
ive read on this forum that 305 vortec heads aren't very good and to use milled 350 vortec heads.any comments?
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
if gas mileage is such a concern, then leave it alone, of course a bigger cam/heads will suck more gas!!!
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
